When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio. The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your vehicle manufacturer's servicecentre and get them to enter this code for you.
there are 3 screens.
1st one is smooth part number 4-071-582-01 subs to 4-081-065-01
2nd one is called lenticular part number 4-070-281-11 alternate part4-070-525-01
3rd one is called fresnel part number 4-070-602-01 alternate number 4-070-602-11
once you remove the screws from the back top and sides you will have screws in the bottom,you have to remove speaker grill to get to them.lay screen flat on floor then remove screws arround screen to take it out-reverse this process to reinstall parts
I have searched for this information for over a year. This manufacturer does not gice a manual to it\'s products. It doesn\'t even have a website! But today I\'ve found the manual so here it is for you to share. Here is direct link.
I won\'t buy this **** no more. I hope this helps.
HRMC 15 Code Scanning method...
1.Press TV device button on the HMRC 15
2. Press Select and Mute simultaneously until TV device button flashes.
3. TV device Button should now stay lit.
4. Aim Remote at TV
5. Press The CHANNEL button UP ...repeat until your TV turns off.
6. Press Power Button to turn TV back on (Thus confirming you found the right code).
7. Press the TV device button to lock in code.
8. ENJOY !!!
