Fuser reset: Press 'system menu/counter' key, select 'service setting', then while pressing 'start' and '#', press 'enter'. Select 'Maintenance mode', then press 'enter'. Enter '163' using the up/down keys, then press 'enter'. Turn machine off to exit Maintenance mode. C6000 indicates fuser did not come up to temp in the allotted time; you 'may' have a bad heater lamp if code reappears. Good luck.........
LG 2945#*# - service menu (code reset)(W3000 G5300 C1200 G7100...) 2945#(*)- hold (LG 500,600) B1200 *+pwr, 6,6,8 Service Menu B1300 *+pwr, 1,5,9 Service Menu
Security Removing Code For Lg 8110,8120. 47328545454# Or 277634#*# LG 2945#*# - service menu (code reset)(W3000 G5300 C1200 G7100...) 2945#(*)- hold (LG 500,600) B1200 *+pwr, 6,6,8 Service Menu B1300 *+pwr, 1,5,9 Service Menu
U8180 old ...............49857465454# U8180 new .............492662464663# U8330 ...................637664#*# U8360 ...................*6*41*12## U8380 ...................525252#*#
ALL LG 2G : 2945#*# 8110 & 8120 : 277634#*# U8130 & U8138 : 47328545454# 8180 old sw : 49857465454# 8180 new sw : 492662464663# 8330 : 637664#*# 8360 : *6*41*12## 8380 : 525252#*#
LG 8550 885508428679#*# Phone Service Menu Code
8110 277634#*#
8120 277634#*#
8130 47328545454#
8138 47328545454#
8180 v10A 49857465454#
8180 v11A 492662464663#
8330 637664#*#
8360 *6*41*12##
8380 525252#*#
Phone Unlock Menu Code
Older phones 2945#*88110#
U880 was told that unlocking code for the phone is "0794070061" and method is to enter 142358#*# but when i enter above code instead of asking for nck code it restarts(phone is temporary unlocked with sim inside). Plz help how to unlock it permanently
1-Press 277634#*# phone will enter Service Menu 2-Select GCF Setting 3-Select GCF On 4-Phone reboot and unlocked working with any sim
Note:This Solution working with only old firmware version
Phone lock,user code - Press 277634#*# phone will enter Service Menu - Select Factory reset - Phone reset and reboot - Phone unlocked (All phone defaul setting).
Unlock LG KH1800 - Press menu - 0 (hold) enter code: 147359 - Phone enter Service menu - Select GCF Test - Select Rel.99 or Rel.15 phone reboot and unlocked
if you need to manually enter the keys a different procedure is required to previous versions of the firmware.
To access the key entry screen try the following:
On the remote press "Menu". Highlight "Language Settings" and press "OK". Highlight "1st audio lang" or "2nd audio lang" or "Subtitle lang" NOT "Menu language", then press the buttons 1,9,6,8 in order. The key entry screen should now be visible. Use the left/right arrow keys or "FAV" button to find the "NagraVision" screen which contains the keys for UK service providers.
to reveal the "Emulation" and "EMM Capture" Highlight "Menu language" , then press the buttons 1,9,6,8 in order.
If all you need is to get into service mode I will be more than happy to help. In fact, I would gladly help you further but it sounds like you know where you are heading. So, to enter service mode. Press "additional functions", then press the numbers 2 and 8 at the same time, then press "additional functions" again. That will put you in service mode . I have to assume you know where you are going and why. Be careful, and take care. SPINAL.............
When you enter wrong code for more than 5 times your mobile gets locked,so if you enter master code/unlock code also your mobile will not get unlock..... Solution :just switch off your mobile ,start it after 15 minutes and enter the unlock code i have given below i.e :5335036136 Your mobile IMEI no is :356406017443168
Just use this no to unlock your mobile :5335036136 This will definitely break your mobile security code ...........enjoy ------------------------------------------- Please let me know your feed-back.
First, you will need to fix the convergence problem by replacing
the convergence IC's,then activate auto focus and last,if necessary, enter the servicer mode................T.
But, have you or not?
