Remove the four screws that hold the covers on the side of the water heater and carefully spread the insulation apart to see the thermostat,reset button and heating elements. The thermostat will have a adjusting screw on it that you can turn with a small blade screwdriver.There is a arrow pointing to temperature setting that you can adjust by turning the screw clockwise to increase the temperature. They normally come from the factory set at 120 degrees so you can turn it up to 135-140 and see if that helps.
Thank you and I hope this helps you.
