Hotpoint Aquarius WF220 Front Load Washer Logo
Posted on Jan 20, 2011
Hi i have a hotpoint aquarius wf220 washing machine, the drum will turn untill (it seems) the clothes get wet then the drum cant seem to turn properly, ive checked the belt as it starts the cycle and the belt continues to spin but with out turning the drum any and all advice welcome
Anonymous
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Jan 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
7291
Points
68
Old belt may be streched replace it and it should be ok first make sure there in no water or oil leaking onto the pulley wheel thankyou
1helpful
Can you help? we have a hotpoint aquirius 1100 waher, the drum seal seems to keep getting dirty, wife keeps machine spotless and allways cleans seal, but constantly gets brown scum going onto washing and...
hi my trick is .................... WHITE VINAGER ...YES VINAGER ... right get 5 ltrs of white not brown or your cloths will STINK :))) now wip some around seal .... tip 2 ltrs into drum ...and rest into powder capartment .... leave for 5 min ...then put on boil wash ...DONT PUT ANY THING ELS IN ..IE CLOTHS OR POWDER.. it normally gose .. wash through x2 times with powder ect b4 any cloths go in . bsc appliances bristol 07779933829 postal service too.
3helpful
Aquarius washer drum stuck
sounds as if the drum bearings have gave way was it noisey b4 this
Dryer not drying clothes
If you remove the lid you will see the element on top of the drum.
There are a couple of thermal cutouts mounted on it which would be the first thing to check.
Also look for the obvious broken wires etc.
Also can you hear the fan running when machine is in operation?
Hope this helps & thankyou for using Fixya.
The drum bangs on the spin
Two possibles for this are aloose balance block or cracked drum spider.The front block is most prone to coming loose.
To check spider rotate drum little by little and pull towards you to check for movement.
Post back if further help needed.
Thankyou
Wf220
belt them out with a cold chisel - this is a brutal job
1helpful
2answers
Hotpoint wf220
Hi, A bleach based cleaner should improve things. It sounds like its a form of mildew , an airbourne fungus that likes damp places. Once bleached it should stay clear for a while. Make sure you rinse it after to avoid damaging your clothes. Hope this helps, Nick.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
