Seeelsie Check the charger's fuse located on the front of the case. If you don't see one then you might have to take it apart to see if there is a fuse inside the charger. Check it to make sure it hasn't blown. If you are getting no lights when you plug it into the wall outlet (at least the red light should be lit) if not and you can't find a fuse then you will have to replace the charger. Maybe you know someone with a chair that has an external charger you could borrow for a few hours to charge your chair until you can get one. any external or offboard charger will work so look around for the best deal. Hope this helps
