https://www.chevrolet.com/.../2009_chevrolet_malibu_owners.pd...
ChevroletDriving Your Vehicle . .... A French language copy of this manual can be obtained ... + : Fuses i : Headlamp High/Low-Beam Changer j : LATCH System Child .... If thevehicle has power seats, the controls used to .... Notice: Folding a rear seat with the safety belts still ..... vehicle's owner, are available in four basic types.
https://www.chevrolet.com/.../2009_chevrolet_silverado_owners....
ChevroletDriving Your Vehicle . .... A French language copy of this manual can be obtained ... + : Fuses i : Headlamp High/Low-Beam Changer j : LATCH System Child .... On a vehiclewith power seats, the controls used to operate .... Notice: Folding a rear seat with the safety belts ..... vehicle's owner, are available in four basic types.
Depending on the design the fuse rating could be on the board, or if you have the original fuse on the case. Say it says 5A then you can replace it with anything up to 5 amps. The type's not that important. A quick blow will do the trick. If it goes again, it's likely to be a shorted part that's causing it.
Fuse Type - There are three main types of fuses used in car audio. The most common is the barrel (cylindrical) fuse which may be an AGC or AGU type. The second most common is the blade fuse which is the type most often found in your vehicle's fuse box. Large blade fuses are used in some fuse holders and may be referred to as a MAXI fuse. The least common type of fuse is the ANL or "wafer" fuse. These are used in the larger fuse holders when high current handling is required. Typically 100 amps and higher. The type you use will depend on the current capacity needed and your own preference. For draws of less than 100 amps expect to use a barrel fuse. For currents larger than that you'll probably be looking at the more expensive wafer fuse.
Cigarette lighter fuse is in the fuse box on he driver side of the car under the dash. It is a blue 15 amp fuse, located on the left of the fuse compartment. You will see 4 rows of little fuses. The 2nd row starts a little further to the left than the 1st row does. The fuse you need is that far left one in the 2nd row of fuses.
