it sounds like you need to use the rewind option first to rewind the tape. If the tape isn't rewound, then you're unable to play it. And this might cause the eject issue that you're experiencing as well.
I hate to say this but you may have wrapped the spook around the player inside. I have not had much luck opening jammed doors that result from spooled up tapes.
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape. Good Luck, Luwangula
I own a Sharp VL-Z1 DV video camera. I had this same problem and thought it was from using the ME Maxell tapes. I took the battery out of the unit and let it reset. Worked fine after that.
