Car Audio & Video Logo
Posted on Jan 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i reset car radio blaupunkt 300 rds vauxhall astra it is set to safe
xxxxxx xxx
Level 3:
  • Blaupunkt Master 5,117 Answers
  • Posted on Jan 20, 2011
xxxxxx xxx
Blaupunkt Master
Level 3:
Answers
5117
Questions
5
Helped
1319969
Points
15645
Switch on using the ON and AS buttons pressed together
Then LEAVE SWITCHED ON ...UNDISTURBED for as long as it takes to automatically reset itself
Once reset , enter the correct code
Press AS and your radio should work
2answers
Cant find code for Blaupunkt CD 300 D RDS
There are only three ways to get a serial number. In your case, the 4th way is to contact Blaupunkt direct.
https://www.fixya.com/support/r29874205-need_vehicle_radio_code
Lost Code for 2000 Holden Astra Blaupunkt 520 Radio
i dont know the code but if you contact the manufacturer maybe a technician can help you no promises i had a few that knew less than me best of luck with your problem
3helpful
3answers
I have 3 Safe on my Holden Astra Blaupunkt Tape player and require a radio Code can some one help please NO 92 057 948 BP8390 1 7391574 Blaupunkt 420
Your code is 3352
To reset from 3SAFE leave the radio SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself
1helpful
I hav the code ect (Blaupunkt 300 ina astra van), now need to know how to install / reset radio
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
Need code for blaupunkt car 300 astra 1998 car
The radio will have to be removed from the car dashboard .Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
1helpful
Unlock opel astra model 2001 blaupunkt car 300(f) GM030MY5875493 7649252520
Can I please get an unlock code for my blaupunkt car 300 (F)
GM030M 15926816
7 649 852 520
Thx alot
2helpful
Blaupunkt 300 f
Hi does it just show SAFE or a number then SAFE?
ie: 6 SAFE
if it does show a number first this is the attempts that you have left to enter the code.
double check that you are getting the ignition voltage to the radio. other than that, you may have a faulty unit.#
Mark
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
