Samsung HT-X200 Theater System Logo
Posted on Jan 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to change my region 2 code to region free
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 27, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2467739
Points
19564
1 Related Answer
muntejaya
Muntejaya Ginting
  • 10422 Answers
SOURCE: Hello I Got Samsung HT-TZ325 Home Theater Its
Hi, kindly get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__4cfbh8
1helpful
Changing region code
You maybe able to get a region free code for your player from one of theses WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Panasonic DVD S1
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Regards, Jay__mlkp
2answers
My compaq laptop says i cant change the region
You only can change this setting 5 times, then it is locked. You can not change the Region code after this even if you reinstall Windows, or move the drive to another computer. You can try upgrading the Firmware for the drive from the Compaq / HP Support page for your product. If that does not work, you will need to replace the drive, or download and install a Region Free software like AnyDVD or DVD Region Killer.
How can i change regional code on panasonic sc-bt207
Regards, Jay__yhg6
1helpful
2answers
Change DVD Region Code
Regards, Jay__okj4
Change to region code 1
This may help you change to Region 1.
There is more than one model of PS2, and more than one PS2 DVD player module. For some models or modules, only a Messiah 2 or Magic 2 chip installation will make them region free.
However, many can be made region free, for free.
Try this Tip for the steps:
Playstation2 Region Free Fix
I hope that helps.
1helpful
2answers
Changing the DVD Region code
New DVD-ROM drives come with a firmware level RPC-2 with hardware protection. RPC 2 drives have a 5 change limit on regions, once the counter gets to 0 your drive is permanently locked to the last region it was set to. Even if you reformat or move the drive to another system it will still be locked to the last region. There are ways to get around it, some models have resetting tools made by 3rd parties to reset the change limit back to 5 and some also have firmware patches to remove the region lock.
The first solution is free VideoLAN player: click here to download VideoLAN.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition Click Start Player button, and try to play your DVD
Finally Load another firmware for your DVD drive which disables the region code protection.
2answers
DVD Player region coding changes
You can only change the region code 4 times then it locks on the last change.
There are some firmware upgrades that can change the drive to region free, if you can screw it up or put in the wrong frmware upgrade then the DVD drive will be a piece on junk.
I suggest you install a region free software that will allow you to play and region DVDs.
Go to www.dvdidle.com to get their Region-Free software, it is not very expensive.
2answers
Need region code 1 for lg dvd player model number v181. ddv/vcr player is region 4
1. Remove any disks & Keep tray open.
2. Press the "Pause" button.
3. Key in "314159"
4. Press "0" when you see "Region code" on the display.
5. Press the "Pause" button.
6. Switch off the player.
7. Switch on again. It's now multi-region!
OR
Turn on Player. Make sure the dvd is selected
Open tray
Type 0 (zero) three times
Region Management test code will display
enter 0 for all regions
Press Pause to return
Region free is now activated.
1helpful
2answers
REGION CODE
Region Code Change
NOTE: Make sure you DO NOT have a disk in the tray while performing the region code procedure
DVD Players
New DVD283
1. Open DVD Tray
2. Press the “Menu” button
3. Press 8888
4. Press the “Display” button
5. Region Code Number shows up. Use the numeric keypad to select your region code number 0
6. Press the “Setup” button to exit.
DVD283
1) Open DVD Tray
2) Press STOP
3) Press 70 plus region code 0 Example 700. Region
5) Wait five (5) seconds; the unit will automatically exit the region code menu.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
