If it is like mine (year, etc) you simply first lay out the ground cloth (if you have one) long-wise, then lay the tent body on top of the ground cloth. Next, stake out both ends of the tent (at head and feet of tent). Now put your poll sets together (the large one is for near the head of the tent, the short for the near foot of the tent). Go ahead and put the polls in the aligned grommets (matching the ground cloth grommets with the tent-body grommets). Once you have the two polls inserted, then clip your tent to them. Now, with your tent erect, Place your fly on top and drape over the tent accordingly; then fasten the fly to the tent using the belt-type nylon clips to do so. In this case the fly does not need to be "staked", rather "belt-clipped" together instead. That's it, your're done. Don't be alarmed if your tent floor seems as though it's lifting off the ground in some areas, this is normal. Just go ahead and put your bed role in the tent and prepare your area as normal.
Most dome tents are assembled by feeding the rounded (or bendable) poles through loops on the inside of the tent cover. Small connectors and joints should be included to put the poles together into the shape below. Good Luck!
there are four pockets on the inside of the tent which hold the ends of the pole with the string in them. connect all the poles with the string in them. bend it in a (n) shape and stick the ends in the pockets. the poles are bent so as to give the tent height not depth, do the same for the rear of the tent. the twelve other poles are connected using the small connectors. one connector for two poles then stick those poles into the front and rear (n) shaped poles in the empty connector spaces already on the pole you bent. remember when you bend the pole they will not stay bent until you stick them into the inside pockets in the tent. the nylon straps at the bottom of the tent help the tent to hold on to the mattress. its simple enjoy. i put all the poles together first and then had my helper to hold it in a (n) shape until i could stick the legs into the pockets. look inside the tent once together you will see where you need to tie the nylon straps to the poles
I just put one of these up today with no instructions so I am going to share my experience. In my Disney bed tent there were two long sets of poles held together by an elastic string. 1) put these two sets of poles together. Now you should have two long poles. 2) Turn the three way brackets all the same direction on both long poles. 3) Lay out the tent and look in each corner of the tent for a little pocket to insert the end of a long pole...taking the other end insert into pocket, not diagonally, straight across the long way. 4) Do the same with the other side of the tent and long pole. 5) Now take your ten short poles and attach two together making 5 medium sized poles 6) Push these into the brackets along the long pole, kind of has a ladder effect. You are done!! I use mine with a full size blow up bed, the elastic gets stretched but I can set it up easily outside, or in the livingroom. Enjoy Nancy
You can call this number it is a number for a number of children's furniture. I called the number and advised that I need an instruction manual for The dora explorer toddler bed and gave the code(BB87008DO) the representative went to try and look for it but she had me on hold for sometime. Go head and call (800) 331-7484 and see if they can get the manual for you. If you would let me know if this works for you.
First you need to open the tent up so you know what your working with.Then find the two longest poles that go into the holes and cover the tent.To connect it to the bed you will need straps to either hold in down or connect it to the bedset
I need instructions
