Transcend 32GB ExpressCard SSD, MLC 32 GB Hard Drive Logo
Anonymous Posted on Jan 20, 2011
TS32GSSD34E-M didn't seen by computer as 32gb drive. Just JetFlash 2Gb, and can't format whole drive.
Dan Woods
Level 2:
  • Expert 103 Answers
  • Posted on Jan 20, 2011
Dan Woods
Expert
Level 2:
Answers
103
Questions
Helped
40536
Points
306
This sounds like a fake card, did you buy from ebay or china? its a cheap 2gb card with a different label on it.
  • Anonymous Jan 20, 2011
    Nope, this was bought on Newegg, and this was previously seen as Transcend, after format it was accessible till reboot. right now computer see JMicron Flash CR Loader section (2GB). Seems need to reinitialize drive, but don't know how to do that.
Kingston 32GB Data Traveler 101 Removable Disk is not available Disk Formate the 32GB Disk
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
32GB Removable Disk is not available Disk Formate the 32GB Disk
hope this helps ya
1helpful
I have kingston 32gb pen drive this working only 1gb remaning 31gb not woked
Try out to format your PD. if format doesn't work try following steps.
steps to format:
  1. right click on my computer.
  2. select manage.
  3. select disk management.
  4. on right side select your drive.
    (tips. your pendrive is in removable media. so see in this group)
  5. right on drive,you want to format.
  6. then select format.
if it doesn't works on your computer. then use updated antivirus or else format it on others computer.
if it helps, pls rate it... ; ) thank you.
4helpful
How to format 32 GB Pen drive?
There is an option called format which can make your pen-drive reliable from virus.
2answers
My kingston 32gb pendrive not format , how to format my pendrive please give me step by step solution thanks & reghardes subhash
normaly your pendrive not formated so cmd (command prompt) use.
Run - cmd (type) than enter
format (pendrive colon) than enter
continue process which computer show
your pendrive is formated.
My Jetflash Transcent 2GB Pendrive Shows 1.75Tb capacity and file system RAW how to fix this
Go to "My Computer", right click the Jetflash drive and click Format.
Select "FAT32" as the File System. Check "Quick Format" Click Start, and hope like hell there wasn't anything important on there.
1helpful
Transcend 2gb pen drive file copying problem
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pen drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
37helpful
6answers
Transcend jet flash v30 32gb pen drive can not be formatted.
first of all transcend do not do a 32gb in V30 - so if its green then its fake - i suggest you try this link it tells you about the fake transcend 32gb - it tells you how to test with h2testw & also you can report the fake from who ever you bought - im hoping you bought via payapl so you can get your money back
http://fakeflashnews.wordpress.com/2009/03/08/transcend-32gb-counterfeit-usb-flash-drive-found-on-ebay-latest-brand-name-to-impacted-jetflash-v30/#comment-92
I cant format my transcend usb 2gb it says write protected
Hi
The pendrive seems faulty or corrupt but there might be a possibility that you recover functionality. I think you might be using XP or VISTA. Whichever the OS use another computer with A DIFFERENT OS (so if its XP go to Vista or vice versa) and FORMAT it. You should be able to get your pendrive working again. If not it is tough luck time!
Cheers
Transcend jetflash 2GB no detecting
ny Transcend jet flash 2GB fingerprint not recognized, any help fpr me pls to format or to find any solution for this problem...
thanx
Basman
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
k24674
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
