PNY 8GB USB 2.0 Flash Drive - Blue/Black Logo
Posted on Jan 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove usb write protection - PNY 8GB USB 2.0 Flash Drive - Blue/Black
Anonymous
Level 2:
Sergeant:
  • Expert 205 Answers
  • Posted on Jan 20, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
205
Questions
Helped
38788
Points
713
Turn on your computer and plug in the drive after your operating system has loaded.
  • 2
    Open "My Computer" and search the list of drives until you find your USB drive letter.
  • 3
    Right-click on the name and click "Properties." Once the options have loaded, go through the tabs until you see the option to remove write protection. If this does not work, go to the next step.
  • 4
    Visit the company website for your USB drive. Go to the help or support section and search for "write protection."
  • 5
    Click on the download section and search for "write protection software remover." Download the program and install it on your computer.
  • 6
    Open the software program. Go to "Option" and click "Remove Write Protection" to unlock your USB drive.
  • Read more: How to Remove Write Protection From a USB Drive ' eHow.com http://www.ehow.com/how_4924168_remove-write-protection-usb-drive.html#ixzz1BY4ve3fh
    2answers
    Cannot format usb says write protected but there is no write protection for the usb
    Reinhard, Check the attached links,instruction and guides on removing USB write protection, Good luck.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    2 ways to fix write protected USB drive or SD card
    How To Fix Write Protection Errors On USB Stick
    How To Disable Write Protection from USB Key
    How to remove write protection on generic usb disk drive
    How to remove write protected on my 2.0 flash drive 64GB usb. I don't have a button on the side to disable it. Please help me.
    Visit following link.. it will guide you how to remove write protection from USB.
    http://www.pcadvisor.co.uk/how-to/storage/how-erase-write-protected-usb-drive-or-sd-card-summary-3633096/
    How to tke write protection off a pny attahe? - Hard Drives ...
    www.tomshardware.com > Forum > Storage
    Tom's Hardware Guide
    Sep 22, 2012 - 6 posts - ‎3 authors
    Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
    Nov 11, 2012
    Remove write protect flash memory USB - Flash Media ...
    Nov 30, 2009
    More results from www.tomshardware.com
    how do i take off my write protection off
    Write protection
    Write protection means you can view the information stored in it but you can't write and transfer the information to it.
    For removing the write protection follow the below mentioned steps:
    1. Right click on the USB stick
    2. Go to properties and uncheck the read only or write only protection option.
    How to remove the write protection in a usb
    1.Turn on your computer and plug in the drive after your operating system has loaded.
    2.Open "My Computer" and search the list of drives until you find your USB drive letter.
    3.Right-click on the name and click "Properties." Once the options have loaded, go through the tabs until you see the option to remove write protection. If this does not work, go to the next step.
    4.Visit the company website for your USB drive. Go to the help or support section and search for "write protection."
    5.Click on the download section and search for "write protection software remover." Download the program and install it on your computer.
    6.Open the software program. Go to "Option" and click "Remove Write Protection" to unlock your USB drive.
    >>>>"M.J Trusedell"
    Gmail.comhow to remove file protected from pen drive data traveler and also please send any link to down load the software
    Kingston Data Traveler2.0 USB Device 4gb write protected remove cannot remove write protected file from usb plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz send me this solution
    email addres- [email protected]
    My verbatim USB 2 GB is write protected. I am not able to remove write protection. Please suggest to solve the problem.
    It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
    13helpful
    2answers
    Write protected 4 GB GENX USB
    I ve a 4 GB genx USB that.It become write protected. How do I remove the write protect so i can reformat it? The device doe't have a write protection switch. What's wrong with it?
    12helpful
    4answers
    Remove the write protection on 2GB USB Kingston Data Traveler 100
    Found this on Kingston site, doesn't help much but may point you in the right direction.
    Unfortunately this unit does not have any security or write protection feature. If you receive a write protection message with this drive, check for the following:
    1. Verify that you are allowed to write to removable storage devices. There may be a security setting in the OS that disables write access to removable storage devices.
    2. Make sure you have not enabled write protection on the drive by using a third party software.
    3. If none of the above apply, the drive may be defective.
    2helpful
    How to remove write protect on my usb flash drive
    On USB stick, there is a "Lock/Unlock" slide bar on the opposite end of USB port. It uses the symbols of a "lock" and an "open hasp lock" to show that the device is "locked" (write-protected) or "unlocked" or not write-protected. remove the lock
    Top PNY Electronics - Others Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Steve Sweetleaf
    Steve Sweetleaf
    Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
