Dryers Logo
Posted on Jul 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to make sure the dryer belt is put on right
Anonymous
Level 3:
  • Master 525 Answers
  • Posted on Jul 16, 2008
Anonymous
Master
Level 3:
Answers
525
Questions
Helped
270821
Points
1508
Your issue is as follows;
"want to make sure the dryer belt is put on right"
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
This link shows belt routing for most makes and models.
Note: you may need to enter your model number to locate your particular models belt routing diagram.
http://www.repairclinic.com/0079.asp
In an effort to improve my quality of answers, please show your appreciation by rating the effectiveness of my answer.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Installing drive belt on a Maytag model lde482 Dryer
http://www.youtube.com/watch?v=6ufArteqWXk
go here and this should help you.when you put the belt on the ribs are up so the smooth side touches the drum,the easiest way is rap the belt around the pulley,feel and make sure the left side of the belt is in the metal v like bracket,with your left hand grab the right side of the belt and pull it to the left to put it onto the motor shaft while with your right hand you push the pulley to the left at the same time,it's a little different from a regular whirlpool belt but you should get it,if it feels like the belt isn't long enough make sure the new belt is on the old mark on the drum.hope this helps.part number for belt is Y312959
Feb 01, 2014 • Dryers
Belt does not go back on with enough tension.
Are you replacing a broken belt? If so then the belt should go flat side of belt in toward drum. Make sure the belt is not in the slight channel in drum put belt from right under guide around idler then insert loop under idler and attach loop to motor. Should end with ribbed side of belt on pulley.
New belt but drum still won't turn
make sure that he put the tensioner on the right way with the spring it will make the belt really tight !This is sometimes hard to do because the spring will bite you if your not careful !!
1helpful
Broken belt on hotpoint vtd65 tumble dryer
if it comes on and runs and has heat but the drum does not turn the belt is broken. To replace the belt unplug the dryer, remove the lint filter, remove the 2 philip head screws,with a stiff putty knife pry up in the top of the cabnet on the right and left to litf the top, disconect the door swithch remove the screw from each side and lift the front off romove the old belt the reinstall put new belt around the drum groove side toward the drum. put the idler pully in the slot closest to the motor be sure the tab is under the base and the 2 catches stit in the slot. now pull the belt through the idler pully and around the motor shaft. the reinsatll the front secure with the screws reconect the door switch,close the top, put the 2 screws back in where the lint filter goes then put in lint filter, plug in dryer and test.
Jan 19, 2009 • Dryers
4helpful
My whirlpool estate dryer tub will not rotate
Dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Drum will not turn
check the belt to make sure that you have it on right
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
1helpful
Belt came loose
BELTS DON'T JUST FALL OFF THERE MUST BE AN UNDER LYING PROBLEM.WHEN YOU FIGURE THAT OUT TO PUT THE BELT ON GET ON YOUR HANDS AND KNEES
REACH IN ONE ARM ON EACH SIDE UNDERNEATH THE DRUM WITH YOUR RIGHT HAND GRAB THE BELT (BE SURE ITS NOT TWISTED) WRAP IT AROUNG THE MOTOR PULLEY.
HOLD IT THERE, NOW WITH THE LEFT HAND PUSH THE TENSIONER PULLEY TOWARDS THE MOTOR
THE BELT SHOULD GO OVER THE MOTOR PULLEY FROM THE RIGHT SIDE. SO IF HOOKED UP CORECTLY THE BELT WILL GO DOWN THE RIGHT SIDE OF THE TUB-AROUND THE LEFT SIDE OF THE TENSIONER PULLEY TO THE RIGHT SIDE OF THE MOTOR PULLEY THEN BACK UP THE LEFT SIDE OF THE DRUM
GOOD LUCK=)
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
