SOURCE: using 2 routers
You may use your wireless router as an Access Point:
1. Connect one of the LAN port of the Belkin to a LAN port on your Voyager. If the link light on both side are not coming on, try using a cross-over cable. Important: Do not connect anything to the WAN port of your Belkin.
2. Configure the LAN IP address of your Belkin in the same subnet as the Voyager. By example, if your Voyager has 192.168.0.1, you may give your Belkin 192.168.0.3.
3. Disable the DHCP server on the Belkin since the Voyager most likely already has one.
4. Configure the Wireless parameter of your Belkin as you would normaly do.
Using this method, your wired and wireless devices will be able to communicate together since they will be on the same network and your Belkin will act as a bridge between the wired and wireless network.
SOURCE: I purchased a mifi 2372
Samething with me. I have a mifi and it can connect to the playstation but cant sign in. It says it a DNS error. Which means one of your DNS numbers have blacked out and it can be fixed by getting knew dns numbers.
SOURCE: My Verizon Wireless MiFi 2200 CB93 is suposed to
First reset your MiFi back to factory settings .Download this manual > http://cache.vzw.com/multimedia/mim/mifi_2200/mifi2200.pdf and go to page #63 for instructions.
Next update the firmware >>click HERE and follow the instructions.
