My Sony KV-35540 is blinking stand by/timer light flashes red television will not turn on. I have tried to unplug the TV and turned it back on. I have tried to hit the reset button and will not work!
I will need to know the model number of your set to help you as well as if the light blinks a certain number of times in between pauses. Please respond to this same post.
KV-35540 isnt a valid sony model number, from any models I am aware of. What contry was the sony made for? so I cant really help untill I know the correct model number.
That model should be blink a error code in between a slight pause. Its hard to notice but it should blink a set rate pause briefly then continue that cycle.
The only codes that register for your model is 2, 4 or 6 , but I am checking further as they may have changed chassis during the model based on serial number as sony is famous for doing that. I will reply as soon as I can locate some more info for you.
I have a 2003 sony kp51ws500 television and there's a timer on the tv and it won't turn on. A red light blinks 6 times then nothing happens. I unplugged, I hit the reset button, nothing happens. I need help please...
The 5V line has an issue usually replacing the B board will solve the issue
My Sony Trinitron model number is KV-35540. The red "standby/timer" blinks at the same rate consistantly and the television won't go on.
Sorry, my eyes aren't as good as they use to be...
KV-35S40
Myself and two other people tried to notice a set of blinks but could not. It blinked about 1 blink per second with no pause, not even a slight pause. We timed for 60 seconds and came up with 57 blinks...does this mean anything?
I think the blink set is 3, slight (almost unnoticable) pause, 3, slight pause, and so on.
how about every three blinks?
I have the same problem. standby timer light flashes red and their is no picture or sound. sony trinitron kv 35540 1998
