Question about La Crosse Radio Controlled Atomic Clock
Both our clocks seem to be losing 5 hours but the minute remain correct?
    Brigadier General:
  • 8,546 Answers
The Time Zone may not be set correctly.
Your particular clock probably has an identifiable control for selecting the time zone you're in.
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
Posted on Jan 19, 2011
SOURCE:
How can I to set clock on Sanyo Microwave EM-C678
1. Open door
2. Press clock/Kitchen Timer button the display will show "0:00" with the hour"0" flashing.
3. Enter the correct hour by turning the potary dial. Enter 1-12
4. Press clock/Kitchen Timer button the display will show "0:00" with the minutes "00" flashing.
5. Enter the correct minutes by turning the potary dial. Enter 00-59
6. Press clock/Kitchen Timer. The colon will remain flashing.
7. Close the door.
Sep 03, 2014 | Microwave Ovens
How to change clock
Setting the ClockIn order to set the clock, the ignition switch must be in the ACC position or in the ON position. The radio may be turned on or off.
In order to set the hour, perform the following steps:
1. Press and hold the down arrow button (HR). After approximately 5 seconds a beep will sound, and the hour will advance.2. Release the button when the correct hour appears.In order to set the minutes, perform the following steps:
1. Press and hold the up arrow button (MIN). After approximately 5 seconds a beep will sound, and the minutes will advance.2. Release the button when the correct minute appears.
Dec 01, 2011 | 2001 Chevrolet Prizm
How do set the time and date on machine
Press and hold CLOCK until the message window displays C, and the default day is announced.
To change the day setting, press MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
Press CLOCK. The current hour setting is announced. The correct day setting is saved.
To change the hour setting, press MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
To change the minute setting, press MEMO/REPEAT or ANNC/SKIP until the correct minute is announced.
Press CLOCK. The current year setting is announced. The correct minute setting is saved.
To change the year setting, press MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
Press CLOCK. The new day, time and year are saved. The correct year setting is saved.
To check the clock, press CLOCK.
The above is from page 5 of the manual at
http://att.vtp-media.com/ecp/documents/product_Product/223/UserManual/944/1739_manual.pt2_i6.pdf
Jun 21, 2011 | AT&T ATT1739 Digital Answering Machine
How do you set the time? I figured out the alarm clock but can't find a way to set up the time.
Setting the Clock
1. Press and hold the HOUR button for 5 seconds (Fig. 5). The time will begin to flash
2. While the time is flashing, press the HOUR button until you reach the correct hour. Then press the
MINUTE button (Fig. 5) until you reach the correct minute.
NOTE: PM indicator will appear on the left side of the clock face for evening hours (Fig. 5). If the
PM indicator is not illuminated, the hour is set to AM. Be sure to set the time for the correct
12-hour period - AM (morning) or PM (evening).
NOTE: After 5 seconds, the time will stop flashing and it will be set.
Mar 03, 2011 | Homedics SS-4000 Clock Radio
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
Two clocks are set at 6am one clock gains 30 seconds every hour and the second clock loses 1 minute every hour. at what time will the faster clock be 30 minutes ahead of the second clock
Compute the difference in clock-speeds, namely 90 seconds per hour.
Convert the units of time: 30 minutes becomes 180 seconds.
So, divide 180 by 90 to get '2', namely 2 hours after the 6 o'clock "start" time, which makes it 8 PM.
P.S. There is at least one error in the above solution. If you truly understand the solution, make the necessary correction, and submit the corrected "homework" to your teacher.
Jan 07, 2010 | M2K Garfield: It's All About Math Math...
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
When I go to messages, it says the time and then says "POWER FAILURE."
Set the Clock
You must set the clock once so that the
with your messages. After this, if you
subscribe to Caller ID, the system will
automatically reset the clock each time new
Press Pto exit at any time while
setting the clock.
1 Press and hold Cuntil the Message
Window displays C, and the default day
is announced.
2 To change the day setting, press and
release ror auntil
3 Press and release C. The current
4 To change the hour setting, press and
release ror auntil
5 Press and release C. The current
minutes setting is announced.
6 To change the minutes setting, press and
release ror auntil
the correct minutes setting is announced.
7 Press and release C. The current
year is announced.
8 To change the year setting, press and
release ror auntil
9 Press and release C. The new day,
time, and year are announced.
To check the clock, press and release
C.
Nov 14, 2007 | AT&T 1738 Digital Answering Machine
La Crosse Radio Controlled Atomic Clock Logo
102 people viewed this question
Top La Crosse Home Experts
Steve Allison
Steve Allison
Are you a La Crosse Home Expert? Answer questions, earn points and help others
