Question about Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive
P: When connected the first time , it was working oke. After try to format it , it stops working and my windows 7 home don´t accept the datatraveler 300 256 GB anymore. Not possible to format or use ´t anymore. Driver Wizz is not helping. Can sombody help my out whit this problem.
SOURCE:
SOURCE: How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
Posted on Jan 07, 2009
  • 7 Answers
SOURCE: i cannot format my kingston datatraveler it says its protected
hello evelymont i found a solution to our problem!!try to download HP USB Disk Storage Format Tool and try to formta the flash stick to fat32 file system!!And after that you're ready to store any file you want unless you put them in a folder first because of the fat32 file system and not saving them on the root for exaple if you want to store an avi file at E: where E: is your kingston usb data traveler save the avi like this e:/name of the folder/avi file, and not in the root e:/avi file!!
that 's it !!congrats for your buy!!
Posted on Feb 25, 2009
Ryan5443
  • 336 Answers
SOURCE: formating process of 2GB write-protected usb
Okay if you right click on the drive and open properties, you should see a check box that says Read Only. Make sure that that is unchecked. If it is already unchecked tell me and I will continue troubleshooting. Then attempt to format the drive again.
Ryan Frame
Creative Energy Associates Technical Center
Posted on May 02, 2009
SOURCE: my datatraveler 64gb dont formating in my
datatraveler dti.4gb ""the disk in drive E is not formatted" how to solve my problem
Posted on Feb 14, 2010
SOURCE: i want 2 run exfat pendrive in windows xp
First, your Windows XP must be either SP2 or SP3, and then you must add a patch to it. http://support.microsoft.com/kb/955704/en-us that is KB955794 for the patch
Posted on Jun 12, 2010
How to install Windows 7 again over administrator rights?
nope it's that way for security hate to tell you but formatting drive is option unless you can install to another partition but then no password
been that way since windows 3.5
May 19, 2012 | Microsoft Computers & Internet
Can you give me an updated product key for windows 7 - MS Office Home/Student 2007. These posts are over a year old and these posted do not work. Help please.
I have/had this same problem while using MS Office 2007 in my lap top running an MS Vista system. I have the disc but for some reason the product key that came with it ceased to be recognized by the system. I contacted MS & they sent me a new PK which I entered & it took care of my problem. Now I tried to use either one of the PK's & they were not accepted. Contacted MS Tech Support
who helped me thru the free MSO 2010 download & all is OK. Hope you can achieve the same results
Dec 23, 2011 | Microsoft Office Professional 2007 Full...
I had to replace a bad hard drive for a Sony Vaio and first installed Ubuntu, now trying to install Windows 7 instead, but won't work...one error message says hard drive needs to be formatted with...
  1. Boot from Windows 7 CD.
  2. You'll be asked to select the language. select your preferable language
  3. Then you'll be asked to accept the license agreement.
  4. Then you'll be asked to choose the drive where windows 7 will be installed.
  5. Select any drive and click format in the advanced drive options.
  6. Your drive will be formatted in NTFS and windows 7 will be installed.!
Nov 03, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Every time I plug in my WD Passport, it pops up tons of messages that ask me "Do you want to format G:\?" I tried formatting it twice, it says "Finished" and when I unplug the drive and...
Odd. Try this:
Connect the drive, don't bother formatting. Right click on My Computer (or just Computer from the Start Menu) and select manage. Click on Storage, Disk Management.
Look for the WD drive Right click on any existing partitions/volumes on that drive and delete them. Right click again and select Create partition (something like that, I don't have a drive to play with in front of me). Accept all the defaults but don't select quick format. Let it do a full format!
If, after all that, you still get that error, it might be the drive failing and you'll want to contact WD for a replacement if it's under warranty. If not, you can get another 250+G drive and swap it out yourself. :)
Jun 30, 2011 | Western Digital WD Passport 250GB Portable...
My sony walkman nwz b133f(b) wont start. when on, it says boot error... what should i do? do u have the firmware availble that i can download myself?
I had the same problem but i solved it.
Follow the folliwing steps.
1- Download firmware nwz-b133f (firmware nwz-b130 V-1.01)
2- Download firmware nwz-b103 (firmware nwz-b100 V-1.3)
3- First execute firmware nwz-b100 , connect your walkman when the programm
asks: please connect device. Then the program ask format your device
you will loose all the data , click accept.
4- Don´t disconnect your device , wait until format and dataload are finished.
This is necesary because firmware nwz-b130 doesn´t do the format.
5- Disconnect your walkman and you will see it doesn´t start (logical it ain´t his
firmware)
6- Now execute firmware nwz-b130 , connect your walkman when the programm
asks: please connect device. Don´t disconnect your walkman wait until program ends.
7- When finished disconnect your walkman the save way.
8- Ready like new.
Greetings Quicktronics here from Mexico.
Sep 11, 2010 | Sony NWZB133F MP3 Player
Printmaster 17 does not save as pdf files under
Here's my solution: Don't waste your time and money on, use a program other than PrintMaster! PDF is universally accepted across formats/browsers/OS ...what kind of program would not export THE most commonly used format????
Dec 15, 2009 | Broderbund PrintMaster® Platinum 17 Full...
My USB mini U3 memorx 2GB does'nt accept my pictures but it did long last time i used.what it could be?
Hello!
You can try format USB, if you system see that USB device. You can also try clean USB contact.
Try USB on another comp.
If this steps don´t help you, buy another.
Dec 06, 2009 | Computers & Internet
My Printer
hi dear
don't connect a printer first,
trying to uninstalling, and remove the instalation manually from program files and windows
if that not work
try to do with system restore
you can choose with date , which your computer running well
oke
Mar 26, 2008 | Office Equipment & Supplies
Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive Logo
94 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
