SOURCE: zanussi zdt6252 stops on 'Rinse & Hold' midway thru Wash Cycle consistently...
The problem here is being caused by Blocked Filters in the Water suppoly In line/pipe. There are two(2) filters in this line, at the water connection point and at the Washer connect point(one at each end). If these filters become blocked, then the result will be a restricted water In-Flow and hence the Rinse & Hold Status. Disconnect the Water-Supply pipe and remove the plastic filters giving them a thorough cleaning before replacing them. All will be rectified by this action. Peter...
SOURCE: My AEG 18 in. Favorit 54750Vi has stopped working.
If for any reason (water leak)the anti flood device at the bottom of the washer is triggered it automatically stops the inlet of water via inlet solinoid and puts the washer in pump out mode. Check the float (polystireene plate with micro switch at the bottom of the washer). Dry any water and determine the reason for water and this should let water in again.
SOURCE: New LG 2131sh dishwasher, have it for 2 weeks,
I would call where you purchased it. There should be a one year warranty on the dishwasher and they should send someone out at no charge to repair it.
SOURCE: Dishwasher goes through part cycle
Hi.
Check if the dishwasher is heating, if dishwasher does not heat, then either thermostat or element is faulty. Both get tested rteading Ohms at their terminals, if either one is open it must be replaced.
If the detergent compartment door does not open, that must also be tested, I think that the slot does not open because temperature is not reached.
There is no much literature on De Dietrich dishwasher. The first thing to do is surely contacting De Dietrich at the number listed here (UK), if you are not located in UK, please use the contact form: Contact De Dietrich.
If you repute this solution helpful, please do not forget to accept.
Best regards.
Ginko.
