Compaq Presario SR1810NX Sempron 3200+ 1.8 GHz Desktop PC ( Monitor Sold Separatley) (ER912AA) Logo
Posted on Jan 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to get the recovery discs - Compaq Presario SR1810NX Sempron 3200+ 1.8 GHz Desktop PC ( Monitor Sold Separatley) (ER912AA)
Anonymous
Level 2:
New Friend:
  • Expert 81 Answers
  • Posted on Jan 19, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
81
Questions
0
Helped
29637
Points
158
Hp/Compaq gives the option and reccommends that you make recovery cd/dvd's but you're only allowed one set per computer.. once you make the original's that's it.. you can't make numerous copies for use on other computers.. If you need them why not use the ones the tech made?
How to make vaio recovery disc for
Follow these steps to create your recovery discs.
From within the VAIO
Recovery Center application, under Choose a program, click Create Recovery Discs.
NOTE: The VAIO Recovery Center can be accessed from within Windows Help and Support. Click Backup & Recovery, then click Launch VAIO Recovery Center.
Next to Create Recovery Discs window, click the Start button.
In the When recovery discs are needed window, click the Next button.
In the Choose your media window, click the Next button.
NOTE: Although an option is provided for creating Dual Layer (DL) discs, that option will not produce usable discs on this model. Ensure the Create recovery disc(s) using... DVD(s) option remains selected before clicking Next.
Insert a blank, recordable DVD into the DVD drive.
In the Insert a blank disc window, click the OK button.
Insert a new disc when necessary as instructed.
When all the disks have been created, click the Finish button.
NOTE: After the recovery discs have been created the first time, any disc can be created again by selecting the disc from the list and clicking Next.
HOW TO MACK recovery disc for vaio vgn-n325e
Follow these directions:
2helpful
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
I need to create recovery disks for my HP Pro Book 4310s in case I need to restore it back to factory settings in the future. I just got this computer and was I told I should get this done. I am running...
Hi.
Please follow the steps to create the recovery discs using the HP Recovery Manager.
Click Start>AllPrograms>Recovery Manager.
Select Recovery Manager. This will open Recovery Manager.
Click Advanced Options. If you are using a laptopand operating on battery power alone you must connect to anAC power outlet before you can go to the next step.
Select Recovery disc creation. Click Next. The Recovery Manager will begin creating the necessaryfiles. This may take a while, so be patient until the bar has reached 100%.
Read the table of requirements thatappears. Depending on the type of discs you use, more or less may beneeded; if you use ordinary CDs, Recovery Manager will require more compared tofewer discs if DVDs are used.
Insert your first blank disc, havingmade sure it is fully labeled, such as "Recovery Disc 01" or"Recovery Disc 1 of 2". The optical drive of your computerwill have automatically opened. If not, open manually. Close the optical driveand click Next.
Understand and confirm you want to gothrough with the operation using the type of disc you have inserted by clickingNext.
Wait while Recovery Manager now createsthe first disc. This may take 20-40 minutes as it collects the files,writes the files and verifies the files to disc.
Remove the disc and insert the nextafter the first has been finished after clicking Next. Continue the creation of discs according to thenecessary requirements, up until the last has finished creating files.
Click Next after removing the disc and then Finish to complete the session. Congratulations! You havejust made yourself a set of recovery discs.
Use the recovery discs to recover yourcomputer in case of system instability or failure.
Thanks!!!!!
My VGN-CR410E laptop looking for installation disc. I failed to make recovery disc? What should I do?
From the information provided, I understand that you are not able to create Recovery Disc from Recovery Center. You can launch Recovery Center by using F10 key. For this, restart the Computer keep pressing the F10 keey when the VAIO logo appears. If you are still not able to enter into the Recovery center, it is required to purchase Recovery disc from Sony.
Please go to the link below for purchasing recovery disc from Sony.
Recovery disc for VGN-AR/CR series
Hope this information will help you, do vote and replay..:)
My pc is lock .my dauther try to many password
Some times the CAPS Lock key may be on, so please make sure that the CAPS Lock key is off.
If the issue still exists, I request you to perform the full system recovery using the recovery disks. To perform this full system recovery, you can use the recovery disks that you have created using the recovery partition.
Use the recovery discs to restore the PC by following the steps below:
1. Insert the recovery disc in the optical disc drive and start the computer.
If the computer is running, insert the recovery disc and immediately click Start and select Restart to force the computer to start from the recovery disc.
2. When prompted, Press any key to boot from CD or DVD, press any key on the keyboard.
3. Allow the recovery disc to start and load the required files while the Microsoft loading screen is displayed. It may take several minutes to load the required files.
4. When the HP Recovery Manager window displays, click Advanced options , System recovery , and then click Next to open the Recovery Manager.
5. Follow the on-screen instructions and perform the required actions.
NOTE: Do not interrupt the recovery process even though the computer may restart and the Windows desktop may display at various times.
· When prompted, follow the on-screen instructions to Backup the user files.
After performing the backup, when prompted, re-insert the recovery disc, and then click Next to continue the recovery process.
· A status box is displayed to indicate the status of the recovery and the estimated time remaining.
· If you used multiple discs when you created the personalized recovery discs, follow the prompts to remove the first disc and insert any requested discs.
6. When prompted to Insert the Supplemental driver disc , take one of the following actions:
· If you purchased a replacement recovery disc from HP, and it included a Supplemental driver disc, insert the disc and click OK or Next . The recovery program checks the supplemental disc and installs the specific needed files.
After the Supplemental files are installed, a prompt is displayed to remove the Supplemental disc and insert the original recovery disc.
· If you purchased a replacement recovery disc from HP, and it did not include a Supplemental driver disc, click Skip or Cancel . The recovery program will ignore the request and install the next file on the recovery disc.
· If you created a personal recovery disc, press Next to continue.
7. Continue following the on-screen instructions to complete the recovery process.
NOTE: If you have not created a personal recovery disc, or the recovery disc fails or become corrupted, see HP Notebook PCs - Order Recovery Discs for Vista as your notebook is preinstalled with Genuine Windows Vista Home Premium with Service Pack 1.
For detailed steps you can refer the provided web link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703
NOTE: Clicking the above link may give an error indicating that it is invalid. If this occurs, copy the link and paste it on the address bar in your browser until the complete address is displayed in the Address box.
If you do not have the recovery disks you can order these recovery disks from the local HP phone support. Please use the provided phone number to contact the local HP phone support.
Phone number: 800-474-6836
I had lost my third recovery disc in vaio vgn-cs280j what i have to do?
You can create the Recovery Discs for the Computer.
  1. Ensure all open programs are closed.
  2. Ensure all network connections are disconnected.
  3. Ensure all peripheral devices are disconnected. NOTE: If the computer uses an external CD/DVD drive, ensure the drive is plugged in according to the instructions in the VAIO User Guide.
  4. From within the VAIO Recovery Center application, under Choose a program , click Create Recovery Discs . NOTE: The VAIO Recovery Center can be accessed from within Windows Help and Support . Click Troubleshoot my VAIO [FIG. 1], and then click Launch VAIO Recovery Center .
  5. In the Create Recovery Discs window, click the Start button.
  6. In the When recovery discs are needed window, click the Next button.
  7. In the Choose your media window, click the Next button. NOTE: Although an option is provided for creating Dual Layer (DL) discs, that option will not produce usable discs on this model. Ensure the Create recovery disc(s) using... DVD(s) option remains selected before clicking Next .
  8. Insert a blank, recordable DVD into the DVD drive.
  9. In the Insert a blank disc window, click the OK button.
  10. Insert a new disc when necessary as instructed.
  11. When all the disks have been created, click the Finish button.
You can call Direct Accessories and Parts Center at: 1-800-488-SONY (7669) to order Recovery Discs also.
1helpful
How do i restore my toshiba laptop with the recovery cd, where can i get the recovery cd
Recovery CD is saved as a recovery partition on the system, which needs to be written/burn onto the CD/DVD.
Steps to create a recovery disc (Insert a blank DVD in the CD/DVD rom) -
1. Click Start
2. Select All Programs
3. Select Recovery Disc Creator.
Recovery Disk Creator
4. Within the Recovery Disc Creator select Create
If you dont have the above options, you need to call the tech support and ask for the recovery disc & it will be shipped to you.
HP MEDIA CENTER 864N Desktop PC&p RECOVERY CD
NOTE: Most HP and Compaq desktop PCs that ship with Windows Vista and XP do not come with recovery discs. Instead, they use a hidden space (partition) on the hard drive to store the recovery information. Using a hidden partition provides a convenient, more stable recovery solution.
Step 1: Create a set of recovery discs or a recovery DVD
To create the recovery disc set, Click Start , All Programs , PC Help & Tools (or similar), open the HP or Compaq Recovery CD-DVD Creation software, and follow the on-screen directions.
If you cannot create recovery discs or your discs have become damaged, continue to the next step.
Step 2: Order recovery CDs on the Web
If you are not able to create a set of recovery discs, you may be able to order a set of replacement discs from HP. HP maintains a stock of replacement recovery discs for several years after the product has been released. However, because of licensing restrictions, HP is only able to provide these recovery discs for a limited time. If your computer is several years past its warranty period, HP may not be able to supply replacement discs for your computer. If this is the case, you can install a new operating system that meets the minimum system requirements of your computer, or, alternatively, upgrade your computer hardware.
To find out if HP has recovery discs that you can order and to order them from HP, use the following steps:
NOTE: The steps in this section apply to United States and Canada. For Europe, Middle East, and Africa please refer to the HP support document Europe, Middle East, and Africa - Statement on the Availability of the Recovery Software on CD . For other countries/regions, contact your local HP support center for information about obtaining recovery CDs.
Go to the Software & Driver Downloads page .
Enter the product number or model name for your computer into the field provided.
Figure 1: Product name/number field
Click the operating system link (the version of Windows that came with your computer).
Figure 2: Example of operating system link
Find the Recovery Disc ordering section and click the link to start the ordering process.
NOTE: Before trying to order, make sure that you have read the important "Read this..." information listed in this Recover Disc ordering section.
Note: - If the link to order a recovery disc set is not available, there may not be any more sets available for purchase. HP cannot create recovery discs that contain a version of Windows that has been obsoleted by Microsoft, such as Windows 95, 98, and Me. Some recovery disc sets may have run out of stock and may not be available to order.
Figure 3: Recovery disc ordering links
Follow the directions from the "Read this...” article and from the ordering pages to complete the ordering process.
NOTE: The ordering pages use a secure connection to protect your privacy.
If you cannot create a recovery disc set and you cannot order a recovery disc set from HP, go to the next step.
Step 3: Contact Support
If you have tried the steps 1 and 2 and could not create or obtain a recovery disc set, contact HP Customer Care . HP Customer Care may be able to send out new discs or replace defective versions depending on your situation and availability.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
