Question about Jensen VM9424 Car Video Player
I installed my Jensen vm9424 about two weeks ago and everything was fine until today. The volume in video/DVD mode is very quiet it needs to be turned up to 40 to hear it and on some dvd's only the background music plays(no dialogue) it this an internal problem or is there a way to adjust ? Audio works perfectly with CDs, Iphone, and Radio.
    New Friend:
    Problem Solver:
  • 6 Answers
Rca jacks either are lose or either one burnt out
Posted on Oct 25, 2017
SOURCE:
SOURCE: Jensen VM9132 07' model
At audiovox.com has some upgrade files for the jensen vm9312 that is supposed to fix this problem. First you have to find the vm9312 and then click on software updates. Audiovox makes Jensen products i believe.
Posted on Jun 26, 2007
SOURCE: jensen in dash dvd/mp3
PUT IN A DVD FIRST AND THEN PUT IN THIS CODE (543210) HOLD DOWN THE 0 FOR 4 SECONDS.
Posted on Jan 20, 2008
SOURCE: jensen vm9412 car dvd/cd
after you put the dvd go to the setup (screw icon in the right) and go to the option where you can set up and test the speakers...click the set up you have 4.1 or 5.1 or whatever you got hit test wait until it hits your sub.....hit the back button and that should do it...
Posted on Sep 01, 2008
SOURCE: video wont play
to solve that there is a pink wire in with the rca's and what not but get extra wire if needed an a toggle switch ground the wire and flip the switch for it to think it is in e brake it works for me!!!
Posted on May 21, 2009
SOURCE: jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
Posted on Sep 13, 2010
I lost some settings in the volume menu and sub volume
did you blow a fuse, or did you blow out your speakers.
Jan 30, 2013 | Alpine iDA-X100 Car CD/ MP3 Player
Lines on screen
The screen has a connection for each line on the display and the soldier on some of these connections has gone intermittent. When the unit becomes warm enough, the soldier expands and the connections become more consistent.
If you're skilled, this can be repaired. If not, either replace the unit or take it to a reputable technician.
Nov 01, 2017 | Jensen VM9424 Car Video Player
Vm9424 unit will not power on pressed reset button and it beeps and lights around function buttons come on and go back off fan comes on for about 10 seconds and turns off checked power ground fuses.is...
Hello lumberjack623,
When the jensen starts acting this way, it is simply a power problem. The device is not receiving power from the main source. The battery is weak and need to be charged before the unit can turn on once again. The battery power is too low to turn the unit on.
Try to check the power source or the connection to the power source. It is not charging the players battery. You need to have the connection port replaced. Also the power connection needs be checked.
The battery is simply weak that is why it goes right off when it comes on.
Hope this was helpful to you. All the best Elect_Comp
Sep 06, 2011 | Jensen VM9424 Car Video Player
WHERE CAN I GET A MANUAL TO INSTALL A BLUETOOTH SISTEM MODEL VM9424 TO MY FORD EXPLORER
Hello there,
Here is a link to the PDF file that you need
http://audiovox2.info/docs/jensen/man/VM9424_DOC_IM.PDF
i hope this was helpful don't forget to Rate
Jan 26, 2011 | Jensen GPS
Jensen UV10 screen wont work it wont come out .its onlyabout 2 weeks old work find untill today
this is a big problem with this type of decks,, if its only 2 weeks old take it back to the store!
Mar 12, 2010 | Jensen VM9510 Car DVD Player
Jensen cd player no longer working(self-installed)
First check the wiring to the radio. You may measure the power being ok but you also need to make sure the ground connection is ok. If this is all ok it may be that you have dry solder joints on wiring socket inside the radio or a blown track or protection diode.
Sep 17, 2009 | Car Audio & Video
Audio problem
Depending on what type of remote you have the DVR volume may need to be turned up. On the DVR remote hold the cable button until the lights blink. Then press volume up. The Light should blink again. Turn your volume up on the DVR to "stereo". Hope that works.
Jan 10, 2008 | Arris DCT6200 DTV Receiver
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Jensen VM9424 Car Video Player Logo
266 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
