SOURCE: the amber lights are blinking next to the printer
There 3 light on the printer that able to indicate to user when problem occur.
1st
button light blink rapidly = the printer may be out of paper, so load
more paper and press the 1st button itself to continue. Or may be paper
jam is occur, so clear the paper jam and press the 1st button light
itself to continue.
If 1st button light blink slowly = mean the
cartridge carriers are stuck, so raise the scanner unit and remove any
object blocking the path of the cartridge carrier, make sure the
cartridge are closed and installed properly, then lift the scanner
unit, gently push the scanner support towards the cartridge carriers,
and carefully lower the scanner unit until it is completely closed.
After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
SOURCE: The exclamation point light on
you have to check paper settings (letter, A4..etc)
For examle - > if you trying to print A4 but printer expecting Letter this error will occur...
If you using Windows XP - .> click start button, then click on Printer and Faxes, select your printer and then click right mouse button on him, select Properties, then click Printing Preferences, now click on tab Paper/Quality and select right paper format...
Rate me if i'm usefull :)
SOURCE: I have a Lexmark X2690
The light indicates either a paper jam or a problem with your cartridges (probably due to low ink or faulty). To identify and fix this issue, please follow the steps below:
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
SOURCE: My Lexmark Platinum PRO905 does ot print it gives
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug your printer into the power source to reset it. When the printer turns on, reconnect the printer into the computer. Try to print again.
You may also refer to this article (for Wi-Fi connection issues): How to identify a Wireless Communication Problem and Resolution Tips
SOURCE: "Communication Not Available" message is displayed
A
and/or rebooting the PC. Simply disconnect the printer from your computer.
Reboot your pc. Unplug and re-plug the printer into the power source to reset
it. When the printer turns on, reconnect it to your computer. Then try to print
again once the computer fully recognizes the USB connection. If
that doesn't help, try the steps below: 1.
Disconnect the printer from your computer. 2.
Unplug and re-plug the printer into the power source to reset it. 2.
On your computer, go to Control Panel > Printers and Faxes. 3.
Delete the Lexmark print object. 4.
Reboot your pc. 5.
When your pc turns on, reconnect the printer. 6.
Wait until your pc fully recognizes the USB connection. To check, go to Control
Panel > Printers and Faxes. If you see a new Lexmark print object in the
list again, then try to print again. You
may also try to update your printer driver by visiting the Lexmark website at .
Select your operating system, download and execute the file. If
the problem continues, please contact Lexmark Technical Support Center for
