run the CLEAN mode. or Remove the toner cartidge and clean the rollers.This happens when you use cheap paper. The dust gets on the roller drum and grays or streeks the copies
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Hello sir; There are two way to get rip off the lines,# 1 , aat the end of the transfer belt there have a cleaning unit , clean up , if need to replace cleaning blade , change it. #2 , after you copy , pull out each drum unit check it out see which drum with the line on it, replace that drum unit.
You need service on your copier. It might just need a cleaning, or possibly a part. If they are random spots on your copies, then there is a good chance the cleaning unit seal needs to be replaced.
