If you have downloaded pictures from your card to the computer the memory card needs to be reformatted to the camera it is being used in. The camera and computer firmware and software are not compatible, you might get away without formatting the memory card a few times but eventually the performance suffers to the point the camera can no longer find clean space to write to. As a rule once you download pictures the card needs formatting.
SOURCE: Memory card formatted in error
when you have formatted a memory card in error the pictures can be retrieved again. using and your pc. You can download and application online to do this. Just do not take any pictures with the memory stick as you will over write the lost pictures. I am using card recovery to find my lost pictures.
SOURCE: CAMERA READS -CARD ERROR-AFTER INSERTING A NEW MEMORY CARD
First, make sure that the new memory card does not have the protect tab in the lock position. The new card must be unlocked and formatted before your camera will be able to use it. Also, make sure that the size card that you have purchased has not over shot the ability of your camera. I think that a 2 GB card is as large as you can use. Just because the card fits into the slot does not mean that the camera will address it!
SOURCE: olympus c-740 reads card error when 1gb xd memory
its non supportive to 1gb card as you will have to get the device upgraded to make it support 1gb.
SOURCE: my Canon powershot s400 camera won't read memory card
First, remove the card, and look in the slot for any bent flash card pins. If you see any, don't fret, it's possible that you can fix this yourself. See this article on how to unbend flash card pins.
But if no pent pins are seen, then the camera's clock battery has worn out, and is likely causing this problem. Unfortunately this battery is internal to the camera. But Canon will fix this for you (for the S400 only) for free, with free shipping. Please see the Canon advisory for your camera here.
SOURCE: pictures taken with camera and no memory card inside how to
There is a copy option on the playback menu.
This copies to and from the memory.
