Video Game Consoles & Games Logo
Posted on Jan 18, 2011
I can log on to my wireless account and get online, but then it i lose the signal, and when i scan, it picks up signal stenght on 90 % but wont connect, I can hard wire it and i get online with no problem, If I shut the system off and restart it, it will scan and pick up my network and allow me to log on. But if i lose the signal i have to shut the system off to find it again. So for wirless service i keep having to cut the system off and on for wirless service. I was wondering if the wi fi wirless is not fuctioning properly.
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Jan 18, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
1822
Points
46
The problem lies in the wireless connection. Either the wireless adapter on the game console, or with your wireless router. Although wireless internet makes it easier to get online and play, it is actually the worst choice for online gaming. this is due to the lag time in the signal relay to the router. Wired internet is the best choice for online gaming. If you can hook your console up to a wired internet connection, then I suggest you do that.
How do I access my online information for MetLife accounts?t balance?
When was the last time you logged into account? If more than 60 to 90 days you may have to call their support. Don't forget some info you enter is case sensitive.
2helpful
Received Nintendo DSiXL for a Christmas gift. Having trouble connecting to the internet. Asking for a security Key? ?
Under nintendo settings internet connection, scan for hot spot and unless your wireless router is unsecured you need to provide the wep security key or change the settings. Your security key is the 12-13 character password used to setup the wireless router if you secured it. If you do not have a router and your picking up a signal you will not be able to log on without the key.
2answers
Router cannot find wireless network
1. check if you have cloned the MAC address in the either the Advanced or basic setup page.
2. After verification of the MAC clone restart the router
3. after router is restart then log in to the router >> go to status page and verify IP Adress.
If no ip address from cable modem then pwer cycle the cable modem >> then power cycle the router.
1helpful
2answers
My ps3 cant find my wireless network anymore
get your router name and go through manual setup, your brother may have accedentally made your wireless network hidden, to change that go to http://192.168.1.1 or .0.1 and log in and chang the settings to default
Lose router signal everytime i restart my laptop
This seems to be an issue with the router itself. As the laptop is able to connect to other networks easily, the trouble seems to be with the router.
Try updating the firmware on the router. Also, change the wireless channel on the router and check if that helps. If the issue persists then I believe you will have to get the router replaced.
Bad connection
Hi i'm ryan, To play online you will need to be close to a wifi location. If you have the internet you will need a wireless router to connect the PSP to. I just recently got a wireless router and since its in the house i have 100% signal connection. If you are using a wifi that you are picking up that is not yours the signal might be weak, or interupted and you will loose connection.
Wireless not working
Yes, There could be alot of things that are causing your Operating System to not obtain signal from your Wireless Router....I would first of all try troubleshooting this by;;
1st - Unplug your High-Speed Internet Modem and Wireless Router for 30 seconds apprx.
2nd - Restart your Computer.
3rd - Once your computer is logged in and at desktop, Plug-In your High-Speed Modem then wait until all lights appear that show your Modem is online then plug-in your Wireless Router then wait about 30 seconds then try to connect to your Wireless Connection.
If these do not work make sure that, you do not have your Wireless Router. I would also recommend that a way to create and obtain a signal strength that the computer can reach please go to the following website http://www.mythings.com/tips/1664/Where-to-Put-Your-Wireless-Router This should assist you with making a stronger signal strength.
Router won't log into it's IP address online
Is your desktop getting an ip address from the router?
You said that you reset the router, do you mean turning it on and off or pressing the reset button?
Internet connection
You trying to connect wirelessly, or wired? If wirelessly, look in your manual on how to log into the router as an admin, and change the channel its wirelessly broadcasting
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
