How to charge battery
The specs on this camera say that it has an external charger. Sometimes the usb cord will also charge the camera, but not all the time (depends on manufacturer). You will have to contact Polaroid, most likely, unless you can find a generic charger at Best Buy, etc.
Here is some information about the internal charger of the camera from redpowers.com:
The Lifespan of the Polaroid T737 Battery
The life of a rechargeable battery for Polaroid T737 Digital Camera operating under normal conditions is generally between 500 to 800 charge-discharge cycles.
This translates into one and a half to three years of battery life for the average user. As the T737 battery begins to die, the user will notice a decline in the running time of the battery. When a battery that originally operated the device for two hours is only supplying the user with an hour's worth of use, it's time for a new Polaroid T737 replacement battery.
Is it Possible to Upgrade the Digital Camera Battery to a Newer Chemistry?
NiCad, NiMH and Li-Ion are all fundamentally different from one another and cannot be substituted unless the Digital Camera has been pre-configured from the factory to accept more than one type of rechargeable battery technology. The difference between them stems from the fact that each type requires a different charging pattern to be properly recharged. Therefore, the Polaroid T737 Digital Camera internal charger must be properly configured to handle a given type of rechargeable battery.
They didn't explain how to configure, but it should be in the software menu of the camera.
I found batteries for this camera on google, but couldn't find a charger. Looks like if you have the right type of battery, the internal charger (through the usb port) will work.
Good luck, thanks for using FixYa, and hope this helps.
