Have you checked for equal air flow? Sometimes letting the freezer defrost completely clears up the problem and clean the dust at the cooling fins while it isnempty and easier to move. Good luck
Because a freezer only does one thing and that is freeze things, unfortunatly any things that breaks on a freezer causes the same thing. Is it running, does the fan work (frost free) are the shelves melting (non frost free) can you hear the compressor running , is the condensor fan running ?
ne of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them
Hello
check that it defrost elements (heater elements) are working if they working then check if the sensor is working and if the door is sealing when its closed or if the drain is open.
Thanks
Are you frosting up at the condensor or did you mean the evaporator? If its the condensor then make sure the coils are clean. Still then you will need a tech to look at the seale system. If its the evaporator and the heater is ok then it could be the timer or the terminator on the compressor. Most of the time its the timer.
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Your defrost timer, switch or circuit board is probably shot or it would be defrosting.
Use a fridge / freezer thermometer to tell if temperture high (it should be 0 F plus or minus 5 degrees) to determine if it is too high - this is normal if frost builds up but will get worse unless repaired.
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting
Need to check the temp to make sure its cold enough.. thats what that alarm is for
