SOURCE: sub woofer has a hum
I have found that with other appliances running, or a busy circuit, I have the same problem. Try to turn everything else in the house off and check again....A/C are often culprits. You can buy a line isolator for the plug, although they are just more money to spend. If this doesn't work, well, it could be a crappy home theaater receiver. It happens
SOURCE: humming noise when woofer turned on
check the NPN and PNP transistor output maybe shorted.....
SOURCE: my sw 15 sub woofer is making aloud humming noise
Most likely, you could feel the fan if it was that, but it could also be the the cord that connects the Sub to the main console, much like guitar feedback on an amp
SOURCE: HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
SOURCE: When I plug the oudio cable into the sub woofer I
Try a different cable, make sure the cable you are useing is not a" twisted pair technology" cable, I have had that type of cable create a hummm in many subwoofers that I have troubleshot. Good luck !
