Hello
Once you have the correct Brother Toner for your printer model, power your printer OFF and open the cartridge box.
Next, you need to open the top cover of the printer. You should do this
carefully to prevent damage to the interior or exterior of the printer.
Once the printer top cover is removed, you want to extract the empty
Brother Toner cartridge from the printer by pulling upward and away
from the machine. You should be able to do this without a great amount
of force.
After you've taken the Brother Toner cartridge from the printer, you
want to prepare the new cartridge for insertion. To do this, you need
to remove it from the plastic bag it is contained in. Next, you need to
remove the rip strip from the cartridge. The rip strip is attached to a
plastic film strip. Removing the rip strip is important because if you
don't your printer will only produce blank sheets. Take care when
ripping the strip off, as you may get Brother Toner on your clothes
which can stain. If you end up spilling toner on yourself you can wash
it off with cold water.
Next, you want to place the new cartridge in the printer the same way
the old Brother Toner cartridge came out. There will most likely be
arrows on the package to guide you in the placement that will help you
make sure you're putting it in correctly. Much like removing the used
Brother Toner cartridge, it should slide in with minimal force. If it
doesn't slide in easily you should make sure that the Brother Toner
cartridge is the correct cartridge for your model printer and then make
sure that it is aligned correctly.
Once you have the cartridge in the printer properly, put the printer lid back on.
Now you are going to print a few test pages to make sure that
everything is working the way it should. If the printouts look good:
You are done. Package the old toner cartridge in the box the new toner
came in and recycle it. If the printouts look bad: Sometimes cartridges
can be defective. If there were problems with your test pages, you may
need to try the process again with another toner cartridge.
