Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
Posted on Jan 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a DC 15 Dyson Ball Vacuum. I've removed and cleaned the filter. I can't get the lid to close properly. I don't want to force it and break something. There is some kind of a red spring loaded tab that seems to be in the way. How do I reseal the top of the vacuum?
Manchester Vacs
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 107 Answers
  • Posted on Jan 21, 2011
Manchester Vacs
Expert
Level 2:
Filmmaker:
Answers
107
Questions
0
Helped
59824
Points
267
The red tab doesn't let the lid close if the filter is not fitted correctly or the wrong filter is fitted. Many after-market filters cause this problem.
Have you recently fitted a new after-market filter?
2helpful
How to remove ball from Dyson dc 25 Animal ?
Remove the torx screws that hold the two halves of the ball shell assembly together, then the ball halves can be separated and removed from the vacuum. Take note of how they come apart and how they line up su you can reassemble them properly.
Dc dyson 24 free repair maule
About 1,100 results (0.84 seconds) Search Results
    Dyson DC24 - Resetting the brush bar (Official Dyson video ...
    ? 1:55
    https://www.youtube.com/watch?v=akGLQ7UbctY
    Sep 29, 2011 - Uploaded by AskDyson
    DC24's brush bar is engineered to shut off for protection if something jams i. ... How to clear and reset the brush bar of yourDyson DC24 upright vacuum cleaner ... Dyson DC24: How toRepair a Loose and Clunky Ball. ... Dyson Ball DC 25 not locking beater bar brush in place while upright - Duration: 17:09 ...
    How to fix your Dyson Vacuum Cleaner when it loses ...
    ? 7:45
    https://www.youtube.com/watch?v=0vd3ldLXgI4
    Apr 16, 2013 - Uploaded by Chuck Fresh
    How to clean the two filters in your Dyson Ball or Animal Vacuum... troubleshooting computer problems, pc helpline, free pc repair... How to take apart Dyson DC 17 to Clean and Service - Duration: 14:33. n4ktz 178,332 views ... Dyson DC24 - Resetting the brush bar (Official Dyson video) - Duration: 1:55.
    [PDF]Dyson DC24 Manualhttps://www.dyson.co.uk/.../Dyson/.../Manuals/DC24_Manual.pdfDysonNote your serial number for future reference. After registering for your 5 year guarantee, your Dyson vacuum cleaner will be covered for parts and labour for.Dyson DC24 Manual - ManualOwl.comhttps://www.manualowl.com/p/Dyson/DC24/Manual/112339Manuals and user guide free PDF downloads for Dyson DC24. ... I Have A Dyson Dc17, Is There A Fuse Or Reset Button On The Vacuum Motor ... Complete Dyson customer service phone numbers and contact information at ContactHelp.com.Dyson DC24 Multi Floor Instruction pack - Part 914529-01 ...https://www.dyson.com/parts/u/user.../dc24userguide.aspx?...DC2...DysonDyson DC24 Multi Floor: Instruction pack - 914529-01.Buy genuine parts and accessories direct from Dyson.DYSON DC24 USER MANUAL Pdf Download. - ManualsLibwww.manualslib.com > ... > Vacuum Cleaner > Ball DC24Page 2: General Safety Precautions. Do not use with damaged cable or plug. If the supply cable is damaged, it must be replaced by Dyson Ltd, our service agent ...
Ball on Dyson DC 25 vacuum cleaner won't rotate
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC25. If the ball won't rotate, it's likely that the post-filter is out of place. To resolve this the filter should be removed then pressed back down into place firmly - you should hear and feel a click from the red filter catch once the filter is correctly secured:
If you have any further difficulty with the ball or the filter after giving this a try, please get in touch directly as I'm confident we can resolve this for you. You can reach our experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dyson dc 15 doesn't turn right
You will need to inspect closely as you move the vacuum to try to find what is causing it to not flow smoothly. There may be worn or broken parts or debris causing something to not mesh as it should.
Dc 15 brush not rotating
Your DC15's brushbar is designed to shut off if something jams it. Once you've removed any obstructions from the cleaner head and cleaned any threads or hair from around the brushbar, you should be able to reset the machine. You may find the video below helpful in doing this - our online Support guide may also be useful:
http://support.dyson.co.uk/support/dc15/dc15-the-ball-all-floors/my-machine-is-not-working/i-can-see-something-wrong-visual/does-the-brushbar-turn-with-the-power-on
This should resolve the issue, but if you'd like any further assistance or advice, please call us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
2answers
The ball is not rolling freely on the dyson dc 25 upright it sticks and makes a noise as the vacuum is pushed
Inspect closely while spinning the ball looking for a rubbing or restriction. Look for a crack or debris that could be causing it. Remove the ball shell to inspect it looking for cracks, check the bearing and the area the ball shell connects to the vacuum to try to find the cause.
Dyson DC07 main filter can it be removed to clean?
Yes, remove the dust bin and set it aside. Using a small screw driver gently pry on the lid that the dust bin sits on. you'll see little holes to insert a screw driver and pry back on the lid. Start on one side and pry at the three points to insert a screw driver and then remove the lid and replace the HEPA filter with a new one from EBay, local vacuum store, Dyson direct, etc. That filter is not washable.
8helpful
3answers
Beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
How to replace dust bin lid
With the lid you need to force it on a little bit its tough plastic but dont force too much.
Removing with out breaking is harder. why do you need it off?
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
