Do you have the administrator access?
If you don't, you might recover administrator login password.
Login With the Administrator Account in Windows XP Professional Click
the "Start" menu and then click "Log Off." Click
"Switch User" when the prompt screen opens. Press
"Ctrl," "Alt" and "Delete." Click
on "Administrator" when the "Log on to Windows" screen pops
up. Type in the administrator password, if applicable. Click
"OK." You will now be logged in as the administrator.
Log On as An Administrator in Windows Vista
Start your computer and
allow it to continue through its startup process. By default your computer will
simply load directly to the primary user account (usually the administrator
account), but if there are multiple users on the system it will load to the
account login screen. Use the mouse to
click on the administrator account from the list of available accounts to log
on. This step is only necessary if you've customized Windows Vista with more
than one account or you have set the operating system to load the login screen
first. Enter the password
required in the password field to log on to the administrator account. Click the
"OK" or "Log On" button once you have entered the password.
This button may be labeled differently depending on the version of Windows Vista
or any GUI (graphical user interface) changes you may have made.
If this answer helpful please vote me. Good luck. Thanks for using FixYa
Log on as an administrator from within the Windows
Vista environment by clicking on "Start" and then "Log
Off." As soon as you have logged off, you will be returned to the login
screen where you can choose the administrator account from the available list.
Log in to your current account and hopefully it has "administrator" setting - it must have this in order for you to create the Administrator account. Go to control panel and select User Accounts. Select Add or Remove User. Select Create user account. Create account with account named "Administrator" then click the administrator circle check.
