Question about Sony Ericsson Audio Players & Recorders
My earphones will not work...when I plug them in the phone "reads" them, but there's no sound coming out of them...
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
Try adjusting your volume. If there is not a volume adjuster on your headphones, try turning it up on your phone. Hopefully it's not a shortage in the wire, which I don't think it is. Hope this solution helps; if not, reply back.
Posted on Jan 17, 2011
2 Suggested Answers
SOURCE:
zeusfaber
  • 247 Answers
SOURCE: Earphones output is mono when plugged into a computer.
You're right - they should just plug in and work.
Some possibilities:
1. Open Volume Control on your computer - if you don't know any easier way, you'll get it from Start_All Programs_Accessories_Entertainment (in XP, at least). Once that's open, check that all the Balance sliders are in the middle of their travel.
2. See if matters improve if you fiddle with the plug - pulling it out a millimetre or two sometimes makes a difference, as can wiggling it from side to side.
3. Try other headphones on the computer - it may be that the sound card is faulty.
A.
Posted on Jan 18, 2009
The hand set does not work I can not talk or recieve. but it will ring when a call comes in and leave information
Ok, here's my theory you used an earphone but it didn't disconnect. To know if this so if you see the earphone icon on your phone then that is the case. This happened to one of my phones. Anyway here is how you can solve this plug in an earphone and shake the plug gently while still plugged in. Take out the earphone. If the icon comes off problem solved if not.... .... Try again. It is usually because of the switch in the earphone jack that switches between headset and handheld mode becoming jammed. :) hope this solution helps
Jan 19, 2016 | Cell Phones
No sound from receiver
this sound me speaker problem, show some repairer to change it or maybe no need to change just disambley and ressambly the device. please can you explain in detail more your problem and your mobile reference,so i can help you perfectly.
Jun 26, 2012 | Cell Phones
Can't make a call do to no sound everything else works but, no sound. I plugged earphones in to listen to music and when I unplugged it I know longer could hear phone calls or when I dial the phone.
Mark, the issue with your phone is with the speaker. This has been confirmed by you when you say the there was sound produced when you used earphones.
You have to get your speaker fixed. Get it done at a local repeir store aroud you.
But in the meantime you could use the earphones for your calls so you can hear them.
But you may still have an issue- hearing your in coming calls- so if you can get a bluetooth headset, that you can hang around your ears, you would hear the calls coming in.
I hope that was helpful to you.
Have a lovely day.
May 27, 2011 | LG CHOCOLATE VX8500 Cellular Phone
I plug in my earphones(with microphone) but the sound keeps on coming from the notebook and not the earphones.
Hi
I think it sounds like you may be putting the earphones into the wrong soacket
can you try plugging into the other socket please and see if that works
Feb 17, 2011 | Acer Aspire One PC Notebook
The sound is coming out perfectly in the right earphone but it is barely coming out in the left earphone
Then you need to adjust the earphones plug in, adjust it gently and it will sound right on both earphone. It is the plug that is causing the problem. Adjusting it will solve the problem for you.
Jan 11, 2011 | ILuv Audio Players & Recorders
Hello, I wanted to get a headset to use for online gaming and possibly using programs such as Skype. So I ordered a Logitech ClearChat Premium PC headset from Best Buy. The headset arrived and I proceeded...
Well in this case you need to include also the infomation of your computer like brand , model and Operating system because the problem is not with the headset. Otherwise you can check the settings right through Control Panel - Sound then Playback and Recording configuration
Jan 09, 2011 | Computers & Internet
Cannot detect when a jack is plugged in.
check your sound card ,,do u have sound threw the pc speakers.if so bad head phones.or not compatable with your pc.
Oct 09, 2009 | Dell A215 Computer Speakers
Samsung G600
you need to go to options while you are listening to music & then select "earphone on"
May 24, 2009 | Samsung SGH-E900 Cellular Phone
Chang Jiang N958
assuming it is a wire earphone which comes bundled with the set then
as soon as u plugged in the set should detect and show 'earphone plugged in', if not the problem is with the earphone itself.
If it is ok and can,t hear, check for the user profile selected as 'Headset'.
Now turn on the radio.
To check whether FM is working or not [diagnostic verify]Warning: DO NOT CHANGE ANY SETTINGS
enter *#66*# to enter Factory mode. Go to the end of the menu & select FM Radio --> select any channel to listen hiss sound. If so the set is ok. EXIT now. Mind that the earphone wire only works as fm antenna for the device that's why radio is disabled by default till it finds the earphone is plugged in.
Keep some space blank in the phone memory as it may be the problem.
if the problem is something else then describe what is happening stepwise.
Oct 08, 2008 | Nokia N95 Cellular Phone
Pioneer sx-315 receiver stays in phones in mode and no sound is coming out of my main speakers
Simply stick the tip of a screwdriver in the input and it will reset. (:
Feb 24, 2008 | Pioneer SX-315
186 people viewed this question
Top Sony Ericsson Audio Players & Recorders Experts
Harrie
Don A
Don A
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
