Computers & Internet Logo
Posted on Jan 17, 2011
Non power speaker stopped working very little usage so not dropped or wires pulled can the speakers be twined if the portal is bad is there any way to replace or rewire the portal on the back of the woofer thanks
5 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Jan 25, 2007
SOURCE: Front Panel Switch wires
If you can see, this is the setup
Anonymous
  • Posted on Aug 23, 2008
SOURCE: Creative cambridge sound work megaworks thx 5.1 550
i lost my Creative cambridge sound work megaworks thx 5.1 550 cable.can i use any other cable?
Anonymous
  • 93 Answers
  • Posted on Nov 14, 2008
SOURCE: asus k7m motherboard connections
The jumpers are located in the lower right hand part of the MB. Here is the user manual (in PDF format), linked from the ASUS website. It has diagrams, and instructions on connecting those wires.
http://dlsvr03.asus.com/pub/ASUS/mb/slota/k7m/k7m-104.pdf
Cheers
Anonymous
  • Posted on Jan 12, 2009
SOURCE: Jamo Cornet 90 IV Speakers - Woofers need replacement
I had the sub woofer problem what i did was i found the fuse in back of the unit i took it out with a srew driver. I looked in the light to see if the tube had a smoke shot in it and it did then i got some aluminum foil just a tiny piece and put it around the tube and low and behold my unit pop back on what a relief. The foil is for testing only you need a fuses to not cause a fire!
Posted by charles on Jan 12, 2009
Anonymous
  • 11 Answers
  • Posted on Apr 28, 2009
SOURCE: Radio wiring problem 2001 Audi A3
Hi, had total issues with this too! Your back speakers arent going because they are amped by the factory amp in the boot. You have to provide power to the amp so that it will turn the rear speakers on. This was a white and black striped wire in my car (Audi A3 1997) The rear speakers are blue /green and brown/red (left rear) , and the LH rear is brown/red and (forgotten colour) but the wire on the bottom left under those two brown/red wires on the 20pin harness. If you wire it all up like this then your rears should be going :)
Testimonial: "So sorry for the very long delay in replying to your advice. It was the sub/amp in the boot as you correctly guessed. Another £200! Many thanks Pal"
Speakers stopped workin in a 2000 Suburban
If you have a non-original stereo, there may be inline fuses in the wire harness leading to the stereo. Look under the dash with a flashlight and see if you can find the harness. Alternatively, you can pull the stereo from the dash and look at the wires that way.
The speakers can be checked by using a 1.5 volt battery. Unhook the speaker wires from the back of the stereo. Then, using jumper wires, MOMENTARILY connect the battery to each pair of speaker wires. If the speaker is good, you will hear the speaker cone move (it will make kind of a scratching noise) as the battery is connected.
If the speakers check out, and you are SURE that the stereo is receiving power and ground at all the correct points, then I'm afraid that your stereo is likely damaged.
My mtx ts5510 stopped working while driving. Was hooked to an mtx thunder 81000 class d and its still working. ????
Inspect speaker for loose wires/broken wires. Check inside box for loose connection. Blown fuse on amp. Ive literally pulled the wires out of the speaker. The little mesh ones from the terminal to the cone. Look for that. If you do find something broken or bad. remember you can call MTX and fix for a flat rate on most evrything they carry. Ive sent several amps there. normally around $100
Everything on my radio works but theres no sound.i did go into the settings and turn on the power IC
Is that no sound for all speakers and the subs sometimes if just one speaker wire is crossed wrong all the speakers will stop functioning . did you just install it your self or replace any speakers or did it just stop working. i would pull it out and look at the wires mainly the speaker wires and turn the radio on while you can still inspect the connections, wiggle them a little. may help,
How do you bridge an Alpine PDX amp
you have 2 + and 2- right? twine both speaker wires together. like + to + and - to - and then pick only 1+ and 1- to hook up and then you should double the power to the speakers only
My subs stopped working after i dropped the power wire on the amp
take the lid off the amp and check the conection on the speaker wire as i would of melted the solder
49helpful
3answers
My speakers stopped working. Cannot increase the volume, have to put ear very close to hear a faint sounds
I fixed a similar problem I was having. It requires a little work.
Take out the four screws from under the broken speaker. Carefully remove the cover, separating the speaker from the base. The two are wired together so don't pull them apart with force. Then remove the single screw, which is much larger the the previous four, and separate the speaker from the top cover.
If you chose you can remove the wires from the speaker, they just snap on, but its not required.
What I found is the speaker issue is not with the wire or the power, but the speaker it's self. On the back there is a big round metal piece. On my speaker that piece was pushed towards the front of the speaker. When I looked at the good speaker, that big piece was all the way back. So I simply pulled it back and presto, instant fix!
I hope this works for you.
2answers
My speaker stop working
Hi
Check the sound drivers in your system and also check whether the speakers have been properly plugged into the system
Thank U
Please rate me as it wil cost u just one click
Left side only speakers stopped working for a 2002 Hyundai Accent
you probably pulled the left speaker wires apart when trying to get it out. there should be enough slack in the wires to pull out or they wouldn't have been able to hook them up. the only way to fix it is to take the player out. if you don't think you can do it have someone who can do it. ( the wires might just be caught up on something, try wiggling a little to free them)
Brother tripped over speaker cord
open up tthe speaker case and resoulder the leads/unless the wires pulled loose from the speaker face on the back of the speakers that should fix the problem,if the wires are pulled loose from the speaker face then reattach them with a drop of craze glue and a small drop of silicone sealer which should do the trick!
Top Creative Labs Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
