Nokia X3 Cell Phone Logo
Posted on Jan 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My nokia x3 wont start after showing the nokia logo, blinked 4 times with white screen and its goes off.WHY
Level 3:
  • Nokia Master 17,130 Answers
  • Posted on Jan 17, 2011
Nokia Master
Level 3:
Answers
17130
Questions
0
Helped
3631768
Points
52372
Remove the battery and the SD memory card, check the card for corrupt/virus infected files that have corrupted the software. Now have it scanned on your PC and remove/format the card.
Reset to the phone and check , if the fault comes back then the software must be installed on the phone. have this done at the Nokia care/support center.
  • Anonymous Jan 05, 2013
    can i install software on the phone myself?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 01, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1040
Points
My nokia x3-00 wont start. when i switch on it shows NOKIA ,then blinks four times and goes off again. i tried removing memory card it wont help either...... plz help me...
Anonymous
Level 1:
New Friend:
  • Posted on Nov 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1040
Points
Me2.Same pblm.Pls help.Bt dnt advice 4 custmr care.Help if u can
1 Related Answer
Anonymous
  • Posted on Feb 28, 2011
SOURCE: my nokia x3 wont start
Same problem here!.... Still looking for an answer, but since mine is just 2 months old I think I'll get the old mobile out of the drawer and send this one back for repairs.. :'
The phone does not switch on, when i press the power button, the Nokia logo shows with a small vibration as usual but then the screen starts blinking white a ferw times before switching off.
Flashing of software is the only way.So try to contact mobile repairing shop or if you want to do it yourself just Click here1 this is only the instruction.Here you can get your X3 flash file Here Thanks visit again.
The phone does not switch on.. when I press the power button, the Nokia logo shows with a small vibration as usual but then the screen starts blinking white a few times before switching off.
Here is your solution read carefully and do it
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link X3 file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gif Inside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
1helpful
The phone does not switch on.. when I press the not switch on.. when I press the power button, the Nokia logo shows with a small vibration as usual but then the screen starts blinking white a few times...
You need to update the firmware.....Today i can't help you so please go to your nearest mobile repairing shop and tell them to flash it.Sorry next I can help you
4helpful
How can i flash my nokia X3 when it got a software problem and does not even switch on. it blinks four times after showing the nokia logo and goes off
well the best option you have is to hard format the phone.
-switch off the phone -press 3 # and answer keys at once and at the same time switch on the phone. -keep the keys pressed until you c text formatting written on the screen.
hope this helps
1helpful
Hello Sir/Madam, Phone Status: I am using Nokia X3 from 3 months, updated recently, but had no problems. But now cryptically, when I changed the sim of my phone, the cell doesn't turn on. Re-inserted...
try this solution, follow these steps: 1. switch on your phone and as soon as it shows the nokia logo, quickly remove the battery ( note that you should remove the battery before the screen blinks) 2. continue this process for at least 7 times. 3.your problem will be solved. 4. if not then you should try to re-program your phone softwares. 5. plz leave good feedback.. thanks...
2helpful
2answers
your phone got deads its happens many times when firmware is not properly updated,try to update your phone firmware but be care or send it to nokia centre
1helpful
When ever i switch on my nokia X3 it shows Nokia Logo and then blinks few times and goes off...i need some help in this regard
The phone application has corrupt. you need to reinstall your phone application, then it become ok. thanks
Aug 16, 2010 • Cell Phones
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
