A
Anonymous Posted on Jan 17, 2011
We have a toshiba e-studio 35 that overheats when we make volumes.The overheating caused the exit rollers to become brittle and break, we need to know how soon can we replace this part as we have been told it is very difficult to get them.
Anonymous
Level 3:
  • Master 1,110 Answers
  • Posted on Jan 17, 2011
Anonymous
Master
Level 3:
Answers
1110
Questions
Helped
544596
Points
4088
You will need to verify which part you need but here are a few links to the parts I beleive you are needing to find along with puctures and prices.
Good Luck and Thank You for using Fixya.
http://www.precisionroller.com/search.php?q=toshiba+studio+35+upper+exit+roller
http://www.precisionroller.com/search.php?q=toshiba+studio+35+lower+exit+roller
Toshiba e studio 232 error code E 010 - Toshiba e-STUDIO
hi
Open the transfer cover. Is there any paper on the transport path? YES Remove the paper. NO Is the exit sensor working? (Perform the input check in the test mode: 03-[FAX]ON/[2]/[B]) NO 1) Check if the connector of the exit sensor is disconnected. 2) Check if the connector CN308 on the LGC board is disconnected. 3) Check if the connector pins are disconnected and the harnesses are open circuited. 4) Check if the conductor pattern on the LGC board is short circuited or open circuited. 5) Replace the exit sensor. 6) Replace the LGC board. YES Is the registration roller clutch working? (Perform the output check in the test mode: 03-108/158) NO 1) Check if the connector of the registration roller clutch is disconnected. 2) Check if the connector CN305 on the LGC board is disconnected. 3) Check if the connector pins are disconnected and the harnesses are open circuited. 4) Check if the conductor pattern on the LGC board is short circuited or open circuited. 5) Replace the registration roller clutch. 6) Replace the LGC board. YES Check the registration roller. Replace it if it is worn out.
How to reset error code E030 in Toshiba e studio 450
U need to check fuser unit, especially the actuator exit sensor is not deformed, following by cleaning exit rollers.
How do I fix Toshiba E-studio 355. When I do the printing the toner dose not hold/stack on the paper, It can be wipe with your Hand. Is it the problem with the fusser?
In general on all machines, after the image is laid down, the toner on paper is run through a heated roller assembly called the fuser. This is normally a heater inside a hollow aluminum roller. As the paper exits the machine it should be warm to the touch. It is most likely your heater is bad.
Drum unit code e020
Check the 2nd transfer roller there was an issue with these and Toshiba issued an updated one. Most in the production line were shipping with 2 one in the machine and one in the box. The setup tech was suppose to switch during setup but I keep finding the wrong one in the machine. These will slow down the drive assembly causing all sorts of headaches.
Also check the exit switch, I have had a bad spring on the actuator that did not return the switch fast enough causing e020.
Toshiba e-studio 35 erreur code 303232
That's not your error code, that's your meter.
Time for periodic maintainance
the machine needs to have maintenance done like replacing rollers ect you will need a certified engineer to do this it depends on the meter reading and when it was last serviced what will be need
Porcelian rollers cracking due to heat overheating
Probably not cracking due to overheating but just due to the heat of the fuser and time. The fuser can not overheat as it is protected by thermal fuses that would blow if the fuser became too hot. These roller will deteriorate over time. This is normal.
Coolant temp and water leak from cup hole
If the vehicle is overheating there will be a build up of pressure in the cooling system and the coolant will push past the pressure relief valve in the coolant reservoir. If this is the case the cause of the overheating would need to be rectified. The cap itself could be at fault. They tend to become brittle with age and the threads break. Check to see if o-ring seal on cap is in position.If not replace cap, not expensive.
Radf problems on e-studio 232
Hello sir; As you said everything is ok, then the only thing you need to do is solenoid problem, replace it. but make sure exit roller clean enough.
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
