You might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
SOURCE: Acer with Windows Vista does not connect to Internet
You're laptop needs to have a profile for the router. Go to Network and Sharing Center, Manage Wireless Networks. Please remove all the listed networks there. Now click on Add, then Add a Network in Range of this Computer. Select the wireless name of your router and connect. If it asks for a network key, please type your wireless security key then connect. That should do it.
SOURCE: Can't connect to some websites with wireless router connected.
access your router with folowng link
http://192.168.1.1
or http://192.168.0.1
then type useranme and password as"admin"
or pasword is blank
then check in filter there id blocking of some sites.disable it.then save settigns and restart router.
SOURCE: Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports. Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys. Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys. If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength. To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address. When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server. You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER. A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER. This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range. A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.
Also, make sure you have DHCP server enabled on the Linksys router for the LAN. This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
SOURCE: computer and wireless router being connected but no internet
To reset the Modem all you have to do is to get a Paper Clip or any object that is like a paper clip then just turn your router to the place where the LAN cables are and just nearby you will see a small button that is abit hidden , so just press that and while pressing it for 5seconds, remove the power cable and plug it back while the clip is still being pressed in the reset button.
Remove that clip from there and you should be able to see that your power light on the router is blinking, wait till it get stable, then all you have to do is login with going to 192.168.1.1 then enter the default username and password which is either admin, admin, or root, password. or root, admin
Then just configure your router again and all shall be well.
THanks.
Hope this helped you.
