Televison & Video Logo
Posted on Jan 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Got a 47 inch flat screen sanyo. tv will power on get a picture for about 10 sec and then turn off. transformer outside of house was struck by lightning
Anonymous
Level 3:
  • Master 675 Answers
  • Posted on Jan 17, 2011
Anonymous
Master
Level 3:
Answers
675
Questions
0
Helped
176329
Points
2146
Sound like you had a power surge that has taken out the invertoer power supply capacitors...these are electrolytic capacitors that will be taken out by surges(it's a veryu common problem)..you can take the cover off the back and look for the power supply board(it will be the one with the ac line cord going to it...look at the cylindrical components on the board to see if they look bloated of have some fluid leaking out of them..this would indicate a bad capacitor...if you don't want to take the unit apart you can take to a shop and have them look at it...note: If you own your home and you have homeowners insurance..it should cover the tv if you had a close lightning strike...just a suggestion
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Model dp46841 sanyo 47 inch tv won't power up
Likely a power board issue. Check that capacitors are OK in the power board, and if blown then replace with exact parts. This is a $10 fix, but if it does not work after than then cost go up like replacing the power board completely.
2answers
I have a 47 inch sanyo. model# dp46848. A transformer blew in a lightning storm and now the tv will not power on. The power light will come on for 5-10 seconds and then shut off. The tv was on a surge...
But, was the cable/satellite feed protected? Lightning can come in from anywhere, not just the power line. The bad thing about the way cable and satellite installers ground things is, they ground to the same grounding system that the house does, which can backfeed the surge through the entire house - it shouldn't, but it can.
I would, however, contact the maker of the surge strip and attempt to file a damage claim. They all come with a liability warranty of some sort.
9helpful
2answers
Tv keeps turning on and off
You probably have blown capacitors on the PSB-power supply board. Recaping with new UF caps works 90% of the time. The set turns itself of into a fault protection to keep from damaging more components internally. A few bucks a soldering iron some solder should do the trick.
1helpful
I have a 47 inch sanyo lcd tv and the screen is broken in the lower right hand corner i want to know how much it will cost to fix and i dont want it will be cheaper to buy a new one
i have a 47" inch lcd sanyo t.v. and my kids accidentally shot it with an air-soft gun. and there is a crack where the pellet hit and there is also a crack running down that spot. Also the screen has these lines running up and down the screen. Different colors. and i was wondering if it was possible to fix.
4helpful
Panasonic plasma tv (47 inches), inputs not working
My 42 inch is powering on but is blank on the screen ..
Tv problems
Unplug the three red-blue-green plugs nest to the convergence amps. If the unit powers up and stays on the picture will look bad but will confirm that the convergence amps have failed...
Replacing the amps and one or more resistors in the yoke return will restore the set to normal operation..
Use only Sanyo original Ics..
Bill
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
