SOURCE: no colour when dvd player connected to tv
I would try a different set of cables to hook up the dvd player, sounds like you either have bad wires or bad ports on either the tv or dvd player. Test each and see which one it is, hopefully it's only a set of cables.
SOURCE: connecting dvd player
the tv should be in video mode in order to accept input from dvd...when it does'nt work try to use a modulator that should be connected at the back through using cable with f-connector both sides...
SOURCE: connect magnavox dvd to ge tv HELP!
There are a few options to connect an older t.v. with a DVD player.
Great way to keep an older working t.v. out of the landfill
hope this helps!
SOURCE: i cant select games mode manually on the symphonic
I think, after you have the rca jacks inserted into the tv and to the game you're playing, youshould be able to move the channel button down past channels 3 and 2. And or hit menu on the tv and look for setup. Try that!
