2004 Kia Sorento Logo
Posted on Jan 16, 2011
My 2008 Kia Sorento is stuck in four wheel drive. How do I fix it? Thanks, Bill
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Jan 22, 2011
Anonymous
Contributor
Level 1:
Answers
31
Questions
0
Helped
22393
Points
86
I assume that the vehicle has a rotating knob on the left side of the dash for four wheel drive. It may have been put into 4 low by mistake. To get it out, start the vehicle and put it in drive, select 4 low on the 4 wheel drive selector, take your foot off the brake and get the vehicle rolling at a walking pace (1-2 m.p.h.) then move the selector to 4 high, stop the vehicle and move selector to 2 high.
2answers
2006 kia sorento stuck in 4 wheel drive low
Get it on the flat road and drive forvard and back while switching the mode, it should get unstuck
2003 Kia Sorento 4 wheel drive will not disengage
Best way to fix it is to lift one side of the car using a jack. Get front and back wheels off the ground. Then put the car into neutral and out of four wheel drive into 2 wheel high ratio. Start the car and rev it up to about 3000rpm for a short while. It should then release the four wheel drive.
It gets stuck mainly because of transmission wind up. Ie tension in the transmission.
My 2003 kia sorento has a flashing warning light with 4 wheels. Can someone tell me what this might possibly mean?
if it is a four wheel drive vehicle it may mean that four wheel drive is engaged.....cheers.
3helpful
2005 Kia Sorento - in 4 wheel drive, on dry pavement, going slow in forward, turning a corner to the left the rear drivers side wheel tries going in reverse and when turning right the passenger side wheel...
Yes, this is normal while in four wheel drive on pavement.
I will try and explain why.
In four wheel drive the front and rear drive axles are linked together by a chain in the transfer case and gears in both axles. This is a direct link with very little play between the front and rear axles.
When cornering a rear wheel will spin faster, or slower depending on the direction of the turn. this causes a binding in the drive line because the drive line wants all the wheels to turn at the same speed. So the wheel "skipping" going in reverse, is the drive lines way of compensating for the different speed of the wheels turning.
Never should a four wheel drive be used on dry pavement. I could cause a break in one of the drive line components. On a slippery surface , snow, mud, gravel, grass, There is enough slippage in the surface to aloow the driveline to compensate for the different speeds of tire rotation.
So do not try at highway speeds on dry pavement.
Your four wheel drive system is working just fine.
Wayne
2answers
Why do light bulbs keeping blowing out on my 2006 Kia Sorento and what is the fix for this issue?
Welcome to FIxYa.com
Depending on which one check the voltage to the bulb if ok replace socket. Could be shorting out
Thank you for using FixYa.com
Regards, Lee Davidian
Hi, i have a kia sorento 2.5 diesel 54 reg, when
I suggest you to check the vacuum hose condition from front diff it may be disconnected,leak or have damage
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
