Xact Communication XTR1 SIRIUS Radio Receiver Logo
Posted on Jul 14, 2008
Satellite radio Need a power cord for xact xtr3 radio. part # cla3 12 volt car cig lighter adapter
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Sep 17, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
855
Points
I have several 'ghettoblasters' that fit this unit if interested --- Frank
Xact XTR2 will not turn on
Its likely that the unit itself is bad. Do you have another dock or boombox to plug it in and trouble shoot with? If it doesn't power up in multiple sources it could be dead. Either way, TSS Radio can help:
tss-radio.com
I have an XACT XTR3. All it does is display "SIRIUS". No response from the remote or buttons except for power.
Flip Display:1. Press the Select button to enter Flip Display.2. Press the Select button to flip the screen upside down so that you may mount the unit on your vehicle's visor.Note:You may also flip the display by pressing and holding the DISPLAY button on the XACTVisor Sirius Satellite Radio Receiver or the Remote Control for 2 seconds.
Manual Here http://www.siriusretail.com/pdf/manuals/XTR3_Manual.pdf
2helpful
Overloaded my inverter -now only works when hooked to car battery
It sounds like the fuse that protects you cigarette lighter is blown.
After you have replaced the fuse, check the voltage again. 0.015vdc would not have powered anything that in manufactured to operate on 12vdc.
When powering anything over about 250W, I would suggest connecting directly to the battery to avoid overloading the lighter circuit.
Delfi Myfi shuts off
Probably bad power. My roady 2 does it with poor power coming in,like on a really long extension cord with other stuff running while camping or something. Or using the car adapter with cheap 12v cig lighter to 110ac adapter.
I am going to install an xact xtr8 satellite radio on my H-D motorcycle. When I was going through the web site that I'm going to order from, I noticed some of the radios run on 5 volts and some on 12....
12 volt is standard the gps system might convert the 12 volts from the bike to 5 volts to run the gps system don't worry just hook it up there is no motorcycles or cars that run on 5 volts
2helpful
My ski fi 3 doesn't turn on
May have a bad docking station? Check power AT THE PLUG. I believe that it is 5 volts.Check fuse inline of the cig adapter by unscrewing the tip. Fuse is inside.
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Top Xact Communication Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
