Bunn NHB Coffee Maker Logo
Posted on Jan 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My bunn makes a hot pot of coffee but If I want a second pot, in the same day it comes out cold
Anonymous
Level 2:
  • Expert 189 Answers
  • Posted on Jan 18, 2011
Anonymous
Expert
Level 2:
Answers
189
Questions
0
Helped
98212
Points
281
From your description, it sounds like the tank heater or thermostat has gone bad. If you will get the date code from the bottom of the brewer and call 800-352-2866 we will be happy to assist you with this issue.
1helpful
Hot water will not come down thru coffee
Your pour over coffee brewer has a reservoir that holds more than a pot of water. First thing you need to do is turn off the machine. Then put the empty coffee pot on the burner. Then take another container and fill it with fresh cold water and pour it slowly into the coffee maker until it starts to come out into the coffee pot. Stop pouring in water.
Now turn the machine on and let it heat up. Now you can brew normally. The reservoir has to be filled before you turn it on or you will end up eventually burning up the heating element.
I just purchased a new a10 bunn coffee maker and it just doesn't brew a hot pot of coffee. It is warm enough to drink without cooling it like my old bunns and the cup of coffee is almost cold before you...
Plug in brewer and turn on vacation switch on side
of brewer. Allow 15 minutes for water to heat to proper
temperature. This is a quote from bunns troubleshooting page. Also it should be under warranty in which case you could go to www.bunn.com and call their service line and either have them send a tech to look at it or have you send it off for warranty repair. Hope this helps.
www.midstatebeverage.com
We have a Bunn thermofresh coffee maker and I use it about 2 times a week. I have lost the instructions and am having a problem. I remember I am suppose to to put a thermo pot of cold water into the...
Are you leaving the machine on all the time? If not, you need to turn it on and leave on for 15 minutes before brewing a pot of coffee. If you will get the model and date# from the bottom of the brewer and give us a call we will be happy to assist you with this.
2helpful
Change gaskets on BUNN model CWT15-APS
  • Brews 3.8 to 7.5 gallons (14.4 to 28.4 litres) of perfect coffee per hour.
  • Large 200 oz. (5.9 litres) tank provides back-to-back brewing capacity.
  • Adjusts automatically to varying water pressure.
  • For high lime areas, BrewLOGIC® technology calculates flow rate and adjusts brew time to maintain consistent pot levels.
  • BrewWIZARD® technology incorporates simplified programming with a LCD display.
  • Quickerinstall saves up to 30 minutes. Pot level, cold brew lock-out and tanktemperature set easily from advanced touch pad on front of machine.
  • Electronic diagnostics and built in tank drain make service easier.
  • Ensures coffee brew quality with cold brew lock out capability.
  • Brew into decanters.
  • SplashGard® funnel deflects hot liquids away from the hand.
  • Coffee extraction controlled with pre-infusion or pulse brew and digital temperature control.
  • Automatic warmer shut-off.
I haveBX-B . I had the pot set up for me to push the on button for Monday Morning, but the water ran throug and it was not on.So now I have cold coffee in the Decanter.
The Bunn coffee maker does not operate as most coffee makes do. You cannot leave the Bunn in the off position and then just flip the switch to on and pour the water in. You will always get cold coffee if you do this. It takes time for it to heat the water. The On/Off switch should be left in the On position all the time. This keeps the water hot in the tank, thus providing hot water when you need to make coffee. You then just pour the cold water in the top, shut the lid, and have a pot of coffee in 3 minutes. The On/Off switch is a vacation switch, and you use it only when you are not going to use the coffee maker for a couple of days. Older Bunn coffee makers did not even have an On/Off button. You simply unplugged them when going on vacation. So turn the switch to the On position and leave it there. The unit will then work as designed. Forget how other coffee makers work, this is a Bunn and it is the fastest coffee maker you can buy and must be left on all the time. that way the water stays hot and the unit will keep it that way.
I have a bunn coffee maker, BT10-13. The reserve water takes very long to reheat after making a pot of coffee. Thus I can't make a second pot of coffee for a long time.
Are you rapid firing your coffee maker?Not designed to do that.. If the water heated that fast it would boil dry if you ever left it unattended and on. The reservoir is heated with the time it takes to drink a full pot taken into consideration for reheating.. If you are serving 20 cups with a 10 cup machine, Expect a delay, especially if you are refilling with cold tap water. Sorry.
How to prep to brew good coffee
Hello, that sounds fairly good, as you describe it. Here is a link to your units manual:
http://www.bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
go to the bottom of the page, and select the operation manual for a VPR. It is advisable to let the unit sit for approx. 20 minutes after filling, cold water works best, and you need to make sure that you pour the water in before you plug it in, as the heat circuit is always on, whether water is in it or not, including if all the water has evaporated. The manual for the unit should answer your questions.
Hope that helps, and thank you.
117helpful
5answers
Tim Horton's home brewer Bunn coffee maker
My Tim Hortons coffee pot leake water out the sides when I add water to make more coffee. What should I do ? I like the coffee maker it makes great coffee,
Bunn coffee maker
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
