2007 Triumph Tiger Logo
Posted on Jan 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i get the wiring through the bars to the heated grips.
Anonymous
Level 3:
  • Master 738 Answers
  • Posted on Jan 16, 2011
Anonymous
Master
Level 3:
Answers
738
Questions
Helped
267575
Points
2102
Hi, are these original equiptment heated grips or aftermarket, most aftermarket grips fit the wireing externaly and not inside the bars as the wire has to turn with the throttle gip, is this a european bike
john morgans
Level 2:
Sergeant:
  • Expert 339 Answers
john morgans
Expert
Level 2:
Sergeant:
Answers
339
Questions
Helped
127195
Points
999
If you remove the pass switch on the left hand switch housing you have room to fit the round rocker switch in the his housing. This makes for a very clean installation. Since in the day time I ride with high beams on the pass switch was of know use to me plus flashing your high beams at a car you intend to over take seems to produce a rather random out come. I traced out the diameter of hole I would need with a scribe and then trimmed it out with a Dremel, test fitting the switch as I went. Much safer then trying to drill a hole that large in a piece of plastic.
Left Side
Right Side
The empty three wire plug under the nose fairing is intended for the factory heated grips. I cut of the plug and wired into the power here. There are three wires, 12v hot, 12v signal, & Ground. The 12v hot use the fuse in the fuse box marked for the heated grips but remains hot even when the bike is off. So I wired in a 12v relay using the signal wire to switch the 12v hot with the ignition. This will prevent dead batteries if I leave the heated grips on or if a passer by feels the need to flip switches on my bike; it's happed before! You will be able to tell which is the 12v hot and 12v signal by pulling the heated grip fuse and show do i get the wiring through the bars to the - 158032656-m.jpge remains hot.
Relay
hope this helps
John
Honda forman 1995 throttle handle getting verry hot. why?
If you bought it used, you probably weren't told someone had installed a heated grip. There are two types: One is the actual grip with a heating element and the other is a thin heating element that tapes onto the handle bar and the grip is slip back over it. Look to see if either on are present on your ATV. If so you may have a thermostat or HI-LO switch to lower the heat.
1helpful
How to install bar ends on a bmx bike
If your grips have closed ends, cut a section off so you have plenty of grip left, but a hole where the bar ends can go through. Follow below procedure with the bar ends.
Bar ends are either have a screw or allen key head. Tap them into the ends of the bars with a rubber mallet. Tighten up the screw/bolt as this will make them expand keeping them inside the bars.
If you need to remove the grips:
Get some hairspray and lift the edge of the handlebar grips up, spray down until the grip is slippy and comes off. (Only use hairspray though, as once it is slippy, it will be very sticky in a minute so it will help when you replace it. Repeat for the other grip. Clean up the bars where the grips were. Refit the grips with more hairspray inside the grip and a little on the bars. Slide them on and leave for a good 6 hours so they stick.
Hope this helps mate, please vote for me :)
10helpful
2answers
Harley Heated Hand Grips not working
The harley heated handgrips are notorious for failing.  Some people have reported finding a loose connection on the ground wire, like they did not crimp the terminal on the end of the wire at the factory.  If they are wired externally of the bars (almost impossible to wire those any other way) then it should be easy to follow the wire down to inside the headlight bucket or in the nacelle or dash, (depending on what model bike) and check the connections.  If both grips quit at the same time then it's probably wiring.  If one quit first, then it may be the grip itself.
If you need to replace them, I would highly recommend not buying the HD brand anymore, and instead choose Polly grip heaters.  They are made for snowmobiles and have a long list of benefits over the HD type: - fits internally in the bar end, so you can use any grips you want - cost $35!!  compared to $250 for HD - easy to install
I have installed over 7 sets in my friends bikes and not one single failure.
3helpful
3answers
Brake assembly
If you loosen the wire that is connected to the gripping machanism first , you will have long enough wire to put it throu the brake grip first then tighten it back at the wheel gripping area.
2helpful
Installing handlegrips
Instructions Difficulty: Easy Things You’ll Need:
  • Razor blade OR Air compressor
  • Flat-head screwdriver
  • Glue cleaner
  • Soft cotton towel or cloth
  • Warm water
  • Pro taper grip glue
Step1 Decide which method you want to use to remove your old motorcycle grips. There are three methods in which you can use. The quickest would be with a razor blade. However, if you fear scratching the chrome or wires are underneath the grips, this may not be the best choice. An air compressor can help slide the motorcycle grips off with ease. However, if they are attached with adhesive, you may need to loosen the glue. A flat-head screwdriver may be your best bet with wires and glue. You can ease the screwdriver between the grip and the bar and pry it up gently without cutting wires or damaging the chrome. Step2 Pop off the bar end of the motorcycle handle. With a flat-head screwdriver, this should be simple. Be careful not to damage these pieces. The threads must be in tack to put them back on. If they become damaged, you will need to replace them. Step3 Using the desired method in step 1, remove the old motorcycle grips. Step4 Clean the old glue from the handle. This can be accomplished with any type of glue cleaner and a little elbow grease. When the glue has been removed, dry the handlebar completely with a soft cloth towel. Step5 Soak your new motorcycle grips in warm water to loosen them up a little bit. This will make it easier to install the grips quickly. Step6 Use your grip glue. You will want to add this around your handlebar where the grip will be placed. You will want to do this one side at a time. There are several methods that are recommended for this task. However, Pro Taper Glue seems to be the most recommended. Step7 Slide the motorcycle grips on each side. When they were soaked in warm water, it will be simpler to slide them on. Again, do one side first, then the other. Step8 Remove the excess glue and water with your cotton towel. This will clean up any mess left behind and give your motorcycle a pristine look. Step9 Let the glue dry for at least a couple of hours. The recommend time can be found on the glue of your choice. Step10 Replace the bar end gently. Be sure to screw it in until it cannot pop off again.
Heated grips on an R850R
My '96 R850R has heated grips which I think are original equipment. In the "Service and Technical Booklet" that came with it, fuse #7 in the junction box is listed as being for the heated handlebar grips. You could see if there's any wiring set up for that fuse on your bike, and it might be a good place to start. The fuses are numbered starting with #1 closest to the left side of the bike, and #7 is a 4 amp fuse.
Where to plug negative terminal on OEM heated grips?
any strait black wire or a good chassis ground.
My '96 R850R has heated grips which I think are original equipment. In the Service and Technical Booklet that came with it, fuse #7 in the junction box is listed as being for the heated handlebar grips. You could see if there's any wiring set up for that fuse on your bike, and it might be a good place to start. The fuses are numbered starting with #1 closest to the left side of the bike, and #7 is a 4 amp fuse.
Top Triumph Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Triumph Expert? Answer questions, earn points and help others
