The last item on this page is the user manual for the Xantrex 300
http://www.xantrex.com/power-products-support/document-downloads/discontinued-products/discontinued-products-backup-power.aspx This is a pdf. Right click, and "save as"
I would suggest it will be almost identical to your 200.
From personal experience, I imagine it uses 12volt lead acid sealed cells, Typically this would use a 13 to 14 volt powersupply probably at 2.5 to 3 amps.
You can also charge the device from your cig lighter socket. See pg 16 of manual.
