SOURCE: Samsung 46" DLP
Did you order an ORIGINAL REPLACEMENT LAMP? There's lots of guys out there claiming to sell original lamps but there really not the original. For Samsung TVs (The majority of them) use Philips branded lamps. Check and make sure you lamp is a Philips lamp. Check out FixYourDLP blog for more information as there's lots o interesting reading there
SOURCE: Samsung 46 DLP buzzing noise dark picture flashing lamp did not turn off unpluged from wall outlet)
Thanks for your solution. This is a problem with color wheel. I could not fix it by myself, so my friend will try to fix it next week.
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
SOURCE: Samsung DLP seems to turn itself off
HI, this is a weak power board that is causing this shutdown. there is a faulty IC on the board that is unable to correctly distribute the necessary power throughout the set at this time.
Simply replacing the power board will fix this issue. This is not a do it your self so, we recommend a professional service tech for this repair.
SOURCE: toshiba 46 in dlp will not turn on
It seems you might have a defective ballast, I mean you just replaced the lamp and it's still not working, the best way to go here is replacing the lballast, that must solve the issue, anyways for a second opinion discountdashmerchantdocom
