To change the temperature display from Celsius to Fahrenheit in a 2018 Toyota Camry XLE, follow these steps:
1. Start the car and locate the climate control panel. 2. Press the "Menu" button on the panel. 3. Use the arrow buttons to navigate through the menu until you find the "Settings" option. 4. Press the "Settings" button. 5. Scroll through the settings menu using the arrow buttons until you see "Units". 6. Select "Units" by pressing the corresponding button. 7. Use the arrow keys to toggle between Celsius and Fahrenheit. 8. Once Fahrenheit is selected, confirm the change by pressing the "Set" button or similar.
The temperature display should now be changed from Celsius to Fahrenheit.
Yes, press and hold '+' and '-' buttons simultaneously for 5 seconds (on the refrigerator side), a tone will be heard and it toggles back and forth between C & F! Be patient for the 5 seconds and it will happen!
If it's holding at 28 degrees, it's not the coils. See if dropping the temp does any thing to lower the temp. If it does, fine. If not, most likely just the control needs replaced or just cleaned.
Save this as a vbscript (filename.vbs) and modify the language as needed. Should be pretty self explanatory let me know if that works. Sub ConvertTemp() temp = InputBox("Please enter the temperature in degrees F.", 1) MsgBox "The temperature is " & Celsius(temp) & " degrees C." End Sub
Function Celsius(fDegrees) Celsius = (fDegrees - 32) * 5 / 9 End Function
Function Fahrenheit(cDegrees) Fahrenehit = (cDegrees + 32) * 9/ 5 End Function
