Singer 8280 Mechanical Sewing Machine Logo
Posted on Jan 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Singer 648 has recently been cleaned, serviced. Has previously been winding bobbin fine, now it will not wind.
Hans Pearson
Level 3:
  • Master 2,510 Answers
  • Posted on Jan 16, 2011
Hans Pearson
Master
Level 3:
Answers
2510
Questions
0
Helped
770219
Points
7758
Ensure that the bobbin winder tyre is in place and not contaminated with oil, causing it to slip. Look to see that the mechanism also moves across far enough to let the two wheels contact to drive the winder.
1helpful
The bobbin presser on my Juki 2000 Qi sewing machine is loose, it spins around and will not let me wind a bobbin. What can I do to fix this?
Be sure you are following the instructions completely. However, it sounds like there could have been a problem with the bobbin winding unit since you purchased it. You can probably take it for service--may be covered under warranty if it was just recently purchased.
However, there is also a standalone bobbin winder (Sidewinder) avlb from JoAnn's, Amazon, etc. for $30. They are usually battery and AC compatible. You can wind multiple bobbins quickly without having to unthread your machine and it saves wear n tear on your machine. Verify that your bobbins will work on the bobbin winder--some bobbins (mostly Singer) will not.
When I fill the bobbin with thread, it doesn't load evenly and bobbin gets jammed.
When you wind a bobbin, the thread usually goes through a "feeder" which creates a tiny bit of tension and a lot of direction. Make sure you have it through this. It is usually two circular discs, cupped, and back to back.
1helpful
2001 Touch Tronic. Worked fine yesterday. Today, why can't I wind a bobbin?
If you haven't cleaned and oiled your machine recently, you might start there. Consult your owner's manual, use ONLY fresh, good quality sewing machine oil, and apply 1-2 drops of oil each spot specified in the manual.
If the machine bobbin winder is still not working, does it still sew? If so, you probably have two choices:
1) Take it in for service
2) Buy a standalone bobbin winder (~$30) from JoAnn's, Hancocks, or Amazon.com
If the machine does not sew, take it for service.
2answers
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Singer touch & Sew machine model 648, the bobbin mechanism wont move all together. I need help!
The bobbin push button (button next to bobbin under the throat plate) must be in the sew position. When it is in the wind ( down to left) the machine will not sew. You need to push the button to the right to release it.
2answers
How do you get the auto threading and wind in place to work on Singer XL6000 sewing machine
There are several FB and Yahoo groups dedicated to the Quantum XL-1000, XL-5000 and XL-6000 who can help you. It may be that your problem with the autothreading is the autothreader is out of adjustment, but I'm at a loss as to the bobbin winder problem.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
