Question about Sony Ericsson Audio Players & Recorders
Booting error - Sony Ericsson Audio Players & Recorders
  • 58 Answers
Download Partition Table Doctor
http://www.fileguru.com/apps/sony_walkman_mp3_nwz_b133f_boot_error/p2
This will rebuild the device!!
Best wishes to you!!!
Posted on Jan 16, 2011
SOURCE:
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
Boot error "Remove disks or other media"
Set the hard drive to boot first, I find this fixes most boot errors.
Jun 07, 2012 | Dell Inspiron N4010 Notebook
Error pxe-e61 media test failure
download new drivers for it, it can be registry error run registry cleaner reg in out may solve the problem
Sep 15, 2010 | HP Pavilion dv1000 Notebook
WHEN I CUT ON MY LAPTOP..AFTER REINSTALLING WINDOWS XP.. ERROR ERROR FOR.. RELTEK RTL8139X/8130/10X PCI FAST ETHERNET CONTROLLER V2.13 020326 PXE-E61 MEDIA TEST FAILURE CHECK CABLE PXE-MOF EXITING...
the system is trying to boot to the Network adapter. If the system boots into Windows after the error, then all you need to do is change the boot sequence in the BIOS (Resetting defaults will likely fix this)
If system is not booting into windows after the error then you may have a hard drive fault
Sep 09, 2010 | Computers & Internet
Sony NWD-B100 Mp3 player , error comming as Boot e...
my sony nwd b100 shows boot error when switching on please give an instn to solve it
May 16, 2010 | Audio Players & Recorders
I visualise this msg on pc 'non disk system error or disk error'
This error is caused by the boot device (hard drive, DVD, etc) not having the required Operating System files. You may need to find a different Boot Device, like maybe a DVD, with the boot files on it. Boot from DVD and reinstall HD files.
Jan 17, 2010 | Computers & Internet
Dvd boot error problem....
That error probably came from the CD ,doing a search on "bootscriptor" returns several links regarding bootable CDs.
Jul 15, 2009 | E-Machines T5082 PC Desktop
133 people viewed this question
Top Sony Ericsson Audio Players & Recorders Experts
Harrie
Don A
Don A
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
