Ovens Logo
Posted on Oct 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Hotpoint UT47X cooker which recently tripped my fuse box. Once I switched it back on the main oven would operate in that the fan continues to work however it will not heat. I am not sure if the thermostat within the oven has blown or if another element is faulty. I would appreciate any feedback as to what the problem could be. Thank you
Level 3:
  • Hotpoint Master 19,187 Answers
  • Posted on Oct 16, 2017
Hotpoint Master
Level 3:
Answers
19187
Questions
0
Helped
4339524
Points
82259
5 Related Answers
Anonymous
  • 66 Answers
  • Posted on Sep 14, 2007
SOURCE: hotpoint electric cooker sy36
it sounds like you have had bad insalltion caused by your element becoming open circit try replacing and this should solve your problem regards jason
Anonymous
  • 359 Answers
  • Posted on May 26, 2008
SOURCE: MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
sounds like the fan element this link will help http://www.ransomspares.co.uk/elements.asp?search_fd6=XOU252
Anonymous
  • 1214 Answers
  • Posted on Jan 14, 2009
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jul 14, 2009
SOURCE: oven element tripped main fuse box switch
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Thanks.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jul 21, 2009
SOURCE: oven not working
You need to detrmine if you are getting a supply to the oven element, if you are , then the new element is faulty, if no supply, then you are going to have to work back from source.
Thanks.
Oven keeps tripping Fisher paykell cooker range When I select function for oven it trips the main fuse box Setting temp sail first does not trip only when I select function ie fan assisted
Make sure there are no exposed wires, this will cause certain wires to touch and rip breakers, and also start a fire, if not dealt with.
2answers
It would appear that the tripping of the switch has caused some kind of short within the cooker. I would look for the continuity of the heating element.
Most likely the wires leading to the heating element have burnt and will need replacement. If you are comfortable with attempting a DIY, well and good. You will have to open the back panel to access the said wires. It should be easy enough to identify..it will be the wire leadingto the heating coil.
If , however, you are not familiar with these kind of things, I would recommend getting a repair guy to do it for you.
Cheers and good luck with the repair!
IrishDruid.
Is it possible for me to get the marking stickers for my oven
Contact manufacturer customer hotline phone# or google search Hotpoint oven UT47X. Marcus
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 07, 2011 • Smeg Ovens
3helpful
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
The main fan assisted oven on a Hotpoint BD35 double oven stopped working so I replaced the element, thinking that would be the obvious answer. Unfortunately it is still not working and I notice that the...
Is there a black pole sticking out that goes in when you close the door, my Hotpoint freestanding cooker has it on the right hand side, once this is pressed in the fan and heat starts, i had to replace it on my cooker as it went faulty and stopped things working (all I had was the main oven light on, these are usually like a little black box that are situated on the side of the oven just behind the main metal panel on the outside and will normally have 2 pull off spade connectors connected to it.
i don't have the same model as you but hopefully this mig help you.
2helpful
2answers
Tricity bendix se211 electric cooker trips all my electrics
The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
Plz rate my solution.
Thanks.
Jan 07, 2009 • Ovens
Top Hotpoint Ovens Experts
Mike Cairns
Mike Cairns
paul fairbanks
goneforever.
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
