Try these procedures.
SOURCE: sony cyber-shot dsc-w200 taking blurry pictures in auto mode...
Its due to slow shutter speed setting.
If you want to take moving object picture, set high speed shutter, there would an icon of golf stick that is for moving object pictures.
SOURCE: Sony Cyber-Shot DSC-W30. The lens is in a "stuck" position
You have a bad lens, it prob. also says turn off and on again.
SOURCE: SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
SOURCE: Sony Cyber-shot DSC- W55 takes blurry pictures
Hi!
The focus doesn't move as it should - it was stuck before you tapped it. Could be sand or something in it. I'm afraid you will have to give it away for a repair. You can contact your local Sony service center, but if they ask too much, I can offer you a very good price. My e-mail is [email protected]
I work in a Sony service center.
Hope this helps!
Tom
