I have an hp laptop (pavillion dv5000) connected to a wireless network (cable modem) with a netgear rangemax wpn824 router. My laptop shows that it is connected with a strong signal, but I cannot connect to the internet. Any ideas??
I got a hp pavillion dv5 it says i got a strong signal to my linksys router but i cannot connect to the internet.I got a hp pavillion dv5 it says i got a strong signal to my linksys router but i cannot connect to the internet.
You can't post conmments that contain an email address.
No you cannot. To make your printer a network printer you need to connect your printer to a network print server and the connect the print server to the Netgear using a LAN cable.
>in order for you not to have more problems at all >first, ask AT&T to set your motorola modem to BRIDGED MODE first >then, connect your Netgear router to the modem >connect the desktop computer to the router and check you connection >after you got the desktop computer connected to the internet >try to establish connection to your wireless network using your laptops (Laptops cannot connect to Motorola modem since it doesn't have wireless capability like routers)
>comments suggestions ratings and violent reactions will greatly be appreciated thank you...
You will need to check the wireless settings of the router is there any computer connected to the router ? If yes then you can open the router set up page on that computer. Router set up page is the page where you can check all the wireless settings of the router.
If nothing was changed in the router after connecting your PS3, possible that the devices are not syncing properly. Do a power cycle. Turn of all of your devices including the router and the modem. Wait for about a minute and turn them on in this order. Modem, wait for the lights to stabilize, then the rotuer, wait for power become solid gree. then turne the Laptop and PS3. See if this will help.
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem.
2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem.
3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router:
'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces'4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled.5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID.6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key. ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
access the router page and you will see the wireless settings. if your wireless network is password protected then you may have to enter the password in order for the wireless router to connect.
Windows, if that's what you're using, may be connecting to a different router than yours. Verify that you're connecting to your access point.
Also, make sure there is a good connection between the router and your cable or dsl modem.
Finally, you can try connecting your computer to the router using an ethernet cable. That will at least let you verify that the computer and router work together, and you can configure the router and so forth. If connecting with a wire succeeds, that narrows the problem down to the wireless network connection.
Here's the manual. Troubleshooting is near the end, but it doesn't look like your specific problem is listed...
