Timing is not very easy. In fact, it is probably the trickiest part of fixing a machine. If you have to fix your machine again involving interrupting the timing, take a very good closeup pucture of the needle and the hook when they are almost touching that is when the needle has gone down as low as it could go and is 'just beginning to rise. And at the same time as the hook is just about to pass behind the needle. As well, take a permanent marker and 'mark' anything (needle bar, bobbin case, etc. ) that will give you an alignment target. That's the easiest way. Having said that. There are many good videos on setting timing. Check out videos by Andy Tube among others.
We know we can buy a manual you greedy people. Thought this was where people help with advice. The machine don’t even cost $60 why would someone buy a manual for that or get “pro” advice for that? It would be cheaper to go buy another used machine.
SOURCE: I need a users manual for a Riccar model 500FA
Visit us at www.ifixmachine.com to avail for a new manual for only $10.00
SOURCE: I am looking for a Riccar 500FA manual.
Visit us at www.janomestuff.com to avail for a new manual for only $10.00
SOURCE: looking for hook gear for
The gear is #53741 and is available at most sewing dealers. The part is also available wholesale at sewing machine services in Canada. Also fits riccar, eatons and babylock machines, so a babylock dealer could help. You will have to beg a repair book or photocopy same to ger mounting and setting instructions. We charge about 60 to install and time the part ONLY.
Derek
SOURCE: I have a Riccar 555su
Hello
Get a manual for the 555, it should be able to give you enough knowledge for your machine.
If not look on the website www. riccar.com for a similar model.
Find out what shank your machine is and you should be able to buy parts for it. I find ebay great for sewing machine parts.
THANK YOU FOR VISITING FIXYA
SOURCE: Setting the hook and needle timing for Riccar
When the needle has risen 2 mm from bottom dead center the point of the hook must be central to the needle and just above the eye.
The
hook should be at the top of its stroke inside the shuttle race. Loosen the set
screw for the needle bar on the upper part of the machine, this is located on
the needle bar bushing (the collar that the needle bar slides through when
making a stitch). The needle bar should slide easily up and down.
Also for instructions with pictures and diagrams.You can obtain the manual.To get manual click this link directly:---
http://www.manualsoncd.com/productdetail-42-Featured.htm
Keep updated.This should help.Thanks.Helpmech.
